yamaha xj400 special
Discussion in 'XJ Technical Chat' started by saintgeorge, Aug 15, 2013.
  1. saintgeorge
    saintgeorge New Member
    manchester uk
    i have a xj400 special, its a jap import,
    its a 1984 model.
    Cant find any real info on it has it was never sold in the uk.
    it has a 4go engine.
    any body know the correct spark plugs for it.
    its had running problems since i bought it and thought i better make sure the plugs fitted are the correct ones.
    I also have a honda cb550/4 that is a pig to start but when i checked the manual i found it has the wrong plugs in it.
    cheers
  2. bigfitz52
    4G0=a true XJ400 (four cylinder.) They did sell them in South America though.
    You can run NGK D8EA plugs (same as the 550s) I do believe.
    Your XJ will need its valve clearances checked/adjusted and its carbs serviced, betcha.
    Does it look like this? This one belonged to a forum member from Santiago, Chile.
  3. saintgeorge
    manchester uk
    yeh thats the one, even same color.
    not worth much i don`t think but what a lovely ride.
    well now i know its time to get on ebay and treat it to some new plugs.
    av already serviced the carbs but not touch the valve clearances.
    would you know the setting ?
    i do keep thinking about putting a 600 into it but not found one at the right price yet.
  4. Krafty
    Krafty Member
    Point Clark ON
    the xj400 is very uncommon, I would try to keep it as original as possible cause someday it will be very very rare.
  5. bigfitz52
    The valve clearances would be the same as the rest of the family, .11~.15mm intake; and .16~.20mm exhaust.
    I covered the procedure here, on my 550: http://xjbikes.com/Forums/viewtopic/t=14827.html
    Here's Part Deux, proper use of and alternatives to "the tool:" http://xjbikes.com/Forums/viewtopic/t=29209.html
    And you can drop an XJ500, 550 or 1st-gen 600 into it with very little trouble; but please do hang onto the original mill.
    When you get into the oddball clutch, you'll need this (it's not the least bit "intuitive") http://xjbikes.com/Forums/viewtopic/t=29541.html
    Your bike is essentially the same as a 550 Maxim, with a 400cc motor. There are a LOT of "4G0" parts on the USA-market 550s. Pretty much anything mechanical that applies to the 550s will apply to your bike.
    Personally, this is my favorite XJ400:
    Toomanybikes likes this.
  6. saintgeorge
    manchester uk
    cheers to you all for your help.
  7. saintgeorge
    manchester uk
  8. saintgeorge
    manchester uk
    after your comments i might stick with my original plan and keep the bike standard and save it till the value increases.
    just not sure it will be sort after as most people look for the bikes they had in there early days, ie i would love a yam rd250. i do have a 1976 honda cb500\4 with a 550/4 engine fitted but its not a patch on the good old 2stroke.
  9. jeffreyxj400z
    jeffreyxj400z New Member
    australia
    if the air cooled 400 is rare.. how rare is my water cooled 4cyl 33m xj400z..? it was released in japan only, it has been imported into australia at some stage and im currently doing the valves, timing chain, carbs etc etc etc.. a slight restoration so it is road worthy and i can register it.. also can anyone give me an evaluation on it.?
  10. a100man
    a100man Well-Known Member
    Bedford, UK
    Let's have a pic then, you ozzy b****** !
    (friendly Ashes season banter)
    jeffreyxj400z likes this.
  11. jeffreyxj400z
    australia
  12. hogfiddles
    Looks like it's based on the fj600! That's cool!!!
  13. jeffreyxj400z
    australia
  14. jeffreyxj400z
    australia
    yeah its kinda more like a mini 900 from the google pics i can find.. there is absolutly no info to be found on it.. well basic info yes but nothing helpfull, the engine was used in the later FZR400R, also a japanese market only bike with no english workshop manual.. did the links work for pics of bike.?
    how can i put a value on this bike being so rare.?
  15. hogfiddles
    The fj600 was a littler chain-drive cousin to the shaft-drive xj900rk and IT'S little sister, the XJ750rl.
    The body panels, rear cowl, rear fender, tank, seat, peg mounts, etc.... All look like fj600 stuff
  16. a100man
    Bedford, UK
    Fj600 in US maybe by in UK it was an XJ600 - I had one ! Engine is probably non-YICS. The 600s though had a fairing and a square headlight - I prefer the look of your 400. They were also the first monoshock road bike for Yamaha I think. I like the indicators in the rear cluster on yours on the 600 they were normal on stalks. Thanks for the pics..
    Day 1, 3rd Test Australia 119 for 9 - ouch !
  17. jeffreyxj400z
    australia
    yes it has YICS on the side cover.. what does that stand for.?
    thanks for the info..! im still unsure how to post my own thread so ive kinda highjacked this one a little bit..
  18. a100man
    Bedford, UK
    'Yamaha Induction Control System' I think. It's a channel that's cast into the head that connects all the inlet ports together
    like a balancer tube. Makes balancing the carbs tricky unless you block it off with a special tool (can be home-made). Search YICS tool on here and you get plenty of hits.
    TBH I'm a bit surprised about that on this model, maybe it has YICS or maybe someone just stuck on a different side cover. Does it say it on the rocker cover too ?
    Cheers
    PS All out 136 ..
  19. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Yamaha Induction Control System is correct. It was fuel saving engineering. There should be a port on the bottom backside of the head with a bolt/washer on either end. That is the yics port.
    Gary H.
  20. Luis
    Luis Member
    Seacoast NH
    NICE BIKE!!! But I gotta ask.. what kind of car / truck / work bench with a vice is that?
  21. EarMachine
    EarMachine Member
    Deep River, Ontario, Canada
    an awesome one?
    lol I was thinking the exact same thing. I want it.
  22. BigT
    BigT Active Member
    Airville, Pa
    I was also wondering, maybe a Holden Commodore?
  23. hogfiddles
    Or just ignore it and do your carb balancing without it. You don't NEED to use the tool. ( yup, opening that flame-war again...... Lol). Oh, and YES-- I have a YICS tool..... and NO, I don't use it .
  24. EarMachine
    EarMachine Member
    So you have it, and say you need it, but you don't use it?
    Is that just because you're so experienced balancing them?
    I will need one.
  25. a100man
    Bedford, UK
    That, my dear friends, is what our Australian cousins call a 'Ute' (utility vehicle) most likley a Holden as suggested ( a division of GM - down under)..
    Neat eh ?
    Must be a sticky wicket -Oz 1st innings 136, England 1st 281, Oz 2nd innings 121-6 and it's only day 2 !
    BigT likes this.
  26. hogfiddles
    No... I said you DON'T need to use one. I've never used one. You can get it darn close without it. If you're retentive, and have to have things perfect, then you might want to get one to use. But then, there are so many other small variables that I don't feel it's worth the time for playing with the tool. Once you're on throttle, it's pretty much a moot point anyway
    Luis likes this.
  27. EarMachine
    EarMachine Member
    Understood.
  28. jeffreyxj400z
    australia
    down under we call them UTES luis, thanks for the info on yics, yes it has this port cast into the back side of the head
  29. jeffreyxj400z
    australia
    and hell no its not a holden!! holden and ford rivalry is huge in aus, im a ford fan! its a1999 model tickford VCT SOHC 4 liter 6CYL ford falcon with manual gearbox and ceramic cussion button clutch.. bit of a handfull in the wet haha, that vice on the back has come in handy sooo many times its not funny!
    BigT likes this.
  30. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Quick note on the Holden... GM did bring a coupe version (I think it was a version of the Commodore) and called it Pontiac GTO. I think it was about 10 years ago. 2 door V8 rwd. Aussies get all kinds of wikked cars we never see. Probably as a thank you for Mad Max.
  31. Luis
    Luis Member
    Seacoast NH
    I'm an auto mechanic by trade and I'll tell you what, this is just a hoot.... love it :)[​IMG]
    and MattiThundrrrr......... cant beat 1970 Pontiac GTO.... affectionately known as a "Goat"...;)
  32. jeffreyxj400z
    australia
    yes the pontiac GTO 2 door coupe you speak of is known as a holden monaro here in aus.. god they are an ugly car IMO..
    the ford has put out a ute, very similar to mine above, with the supercharged coyote engine out of a the mustang.! traction is over rated in australia mate hahaha
  33. jeffreyxj400z
    australia
    well ive done valve clearances, synced carbs, free'd up a seized bush in the rear suspension, then found the shock to be leaking found a good used one at local bike wrecker from a xj600, exactly the same shock and spring! so now ive got head set bearings to go and its ready for a roadworthy certificate and registration for road use!! im just a little bit excited.!
    rocs82650 likes this.
  34. a100man
    Bedford, UK
    Good work.
  35. MattiThundrrr
    Trust me, Luis... I know the original GTO. OOPS! The original GTO was a Ferrari! It means Gran Turismo Obligato (or something. I can't remember what the O word is exactly). I mean the original Pontiac, aka "The Judge". Some credit it with starting the muscle car wars. I'm still mad at GM for killing Pontiac. Why Pontiac and not Buick? Seems like a mistake to me.
  36. rocs82650
    Middle Tennessee
    @MattiThundrrr: Why Pontiac and not Buick? Ooh, ooh, pick me (with raised hand). Uh...more $!
    Gary H.
  37. MattiThundrrr
    Yeah, old people and their options... but then they re-branded Buick, and it isn't much more fancy than Chev. Plus they've got that angle covered with Cadillac. In my always awesome opinion, the high performance aspect of Pontiac should have been played up more. Can you see a Firebird or a Pontiac Corvette selling more than Buicks do? I sure can! Plus, that 4cyl Solstice was a damn fine car. The rare coupe is so cool looking. Could have capitalized on the sport compact market the way that Toyota/Subaru are with that flat four rear wheel drive thing. FFR, FRS, BRZ, whatever, I can never remember those alphabet soup names!
  38. Luis
    Luis Member
    Seacoast NH
    I'm a lot of bit excited jefferyxj400z, good luck... Spot on MattiThundrrrr.. Gotta love those early ones...... Just like my bike... Love it!!
  39. Toomanybikes
    Tsawwassen bc
    They missed on solstice buy not going hi perf v6 twin cam!
  40. jeffreyxj400z
    australia
    just got back from a 500klm round trip, what a lovely bike to ride, does everything you want it to, with out breaking your neck.! am going to find out one way or another if the magneto and clutch is the same between the xj600 and xj400z as they are the only things i can fault with my bike, if anyone on here can tell me how to post my own thread on asking these questions that would be very helpful.. or point in the direction of someone who would have an idea about this.. thanks!
    gunnabuild1 likes this.
  41. gunnabuild1
    gunnabuild1 Member
    Nice looking bike jeffrey400z and good work on getting it all done.
    BUT you managed to bring out the poms about the cricket and at this point in time that means a deduction of bonus points.
    If you take a look here http://www.xjbikes.com/forums/forums/xj4ever-supporting-vendor.23/
    You might just find the info you need,haven't looked but Chacal has pretty much all the info you might need about XJ's
  42. jeffreyxj400z
    australia
    thanks gunabuild.! ill check it out
  43. jeffreyxj400z
    australia
    cant find much or any info or parts for the 400z through his pages.. wow is all i can say, so informative and easy to understand granny could fix her bike with some tools reading through his pages..!
