Is this normal?
Discussion in 'XJ Technical Chat' started by pillowmaster50, Sep 1, 2013.
  1. pillowmaster50
    pillowmaster50 Member
    Hey,
    I think excessive backlash is causing my rear tire to wear out too quick. Here's a video I made:
    http://www.youtube.com/watch?v=-oJnrTfGxyc
    Does this seem like a normal amount of back and fourth? It's in 1st gear.
    My rear was leaking so I got this one off ebay. It supposedly had less than 10K miles on it... I think my old one had less play.
  2. k-moe
    That looks like a normal amount of backlash (remember, there are 2 sets of 90º gears between the rear wheel and the gearbox), and excessive backlash won't cause a tire to wear out faster.
    What tires do you have?
    How often do you check the air pressure?
    How aggressively do you ride?
    Do you ride two-up with gear, or solo?
    Are your rear shocks kaput?
    What mileage are you getting out of the rear?
    Do you live in the "Land of Straight and Boring Roads" (the plains states)?
  3. Polock
    that looks pretty good to me. it should have no sideways play though.
  4. pillowmaster50
    Currently I've got metzeler marathons. It's got less than 3000 miles and needs replacement. Front is wearing to a point. I've never got more than 3000 without riding on a bald tire.
    Every week or so.
    Very aggressively.
    Not often enough to speak of.
    They're not pogo sticks at least.
    Less than 3000
    I live in the land of the twisties.
    I was thinking excessive lash contributes to wear when I let off the throttle and then the rpms drop while the lash is being taken up so it skids a little when the lash is all taken up and hits the engine break...
    If it looks good to you guys, I'll just chock up my tire wear to aggressive driving...
  5. Polock
    there is a drive damper in the middle gear assembly to take up the on off shock and you can adjust the lash on the final set of bevel gears.
    but there's really no more play in yours than most chain drive bikes
  6. bigfitz52
    Wait, whoa.
    "My rear was leaking so I got this one off ebay. It supposedly had less than 10K miles on it"
    So this is a USED tire? Did you check the date code? How about the date code on the previous tire?
    If you're only getting 3000 miles out of old, or "less than 10K" used tires I'm not surprised.
    Try a set of brand new tires and see how long the rear lasts.
    After you replace the rear shocks. If original, at 22K they are toast whether you realize it or not.
  7. hogfiddles
    I get ballpark 3k or so out of a rear tire.......
    Most of my roads are straight, so I wear out the center while the nubbies can still be on the side. Just not enough twisties hereto spread out the miles, but I don't care for them anyway.
    Dave F
  8. BigT
    BigT Active Member
    Airville, Pa
    I think he got a used rear drive hub off of eBay instead of a rear tire.
  9. Polock
    it's the used air he's putting in the used tires, always make sure you get the original air that came installed from the factory
  10. k-moe
    If the OP's sentence is read as written; he was speaking about having replaced a leaky rear drive, not a rear tire.
  11. pillowmaster50
    Haha sorry I got a used rear drive off of ebay. Tires were new last summer. I've put like 4 or 5 rear (brand new) tires on this bike since I've owned it.
    It seems like this wear is normal, so I'll just expect this kind of wear from any tire I get.
    I forgot that that middle gear has a huge spring on it... Thanks Polock. Also I only fill my tires with purified argon ;)
    I need to update my sig, the bike actually has 28k on it now, so I guess my shocks are really shot huh? Len's about to get over a grand from my R1 fund so the shocks will have to wait. I assume they're not cheap.
    Thanks everyone
  12. Orange-n-Black
    Memphis Area
    DOH, now I have to change the air in all my tires.
  13. crewwolfy
    crewwolfy Member
    Chicago, IL, USA
    Ha, initial reading, I was on the same page as the Fitz. Never buy used tires.
    Since that isn't the case.. I get 10K+ out of my Shinko rear on a bike much more powerful. Marathons are 'ultra mileage' rated, so something's up. Aggressive riding will have something to do with it, but nothing that dramatic. My initial reaction is that some alignment of the rear wheel is off? But my Seca's been 'under construction' for a couple years, so I can't remember if that's possible..
    * Is the rim true & straight?
    * Are the tires professionally replaced? Properly balanced?
    * Are the rear brakes dragging? (doesn't look like they are)
    Backlash looks fine.
  14. pillowmaster50
    It's the straightest rim I've ever seen! Front has maybe a 50thou wobble.
    They were professionally mounted and balanced this time (first time I've had them professionally done).
    No.
    Maybe the frame's a little crooked?
    There seems to be 2 kinds of mileage reports from what I've turned up; there're people who get 10k+ out of their tires, and then there's people like me who get around 3k.
  15. k-moe
    How many miles you get out of a tire boils down to five factors (assuming there are no mechanical issues) the type of tire (sport v. touring), how aggressively you ride, maintining proper air pressure, the types of roads you ride on (concrete v. tearmac v. chipseal v. gravel), how much weight the tires are carrying (one up v. 2 up luggage).
  16. althomas101
    althomas101 Member
    Baltimore, Md
    The Avon AM26 Road riders seem to last forever, and the grip on the ones I have on my Honda 750 is pretty good. Maybe you should try a different brand/style of tire.
  17. burger
    burger Member
    MN
    I think the tires need some fresh air.
    Im hoping to get 5k out of my rear tire. Im at about 3500 and its pretty worn in the center. But i ride aggressivly and have done a few burnouts on the tire
  18. althomas101
    althomas101 Member
    Baltimore, Md
    Well I ride my GS1000 hard and it uses the same 130/90-18 rubber, I'm getting 5K out of a shinko 230 and that bike has a lot more torque than a 700. My CB750 gets 7k from a sport deamon, and 12K from a AM26.
