new proud member
Discussion in 'Hangout Lounge' started by Saltys, Sep 10, 2013.
  1. Saltys
    Saltys New Member
    West Georgia, USA
    Must say thanks for letting me join this wonderful website. My name is andrew and I'm from Georgia and picked up an 83 xj750 maxim a few weeks ago for 800 bucks. It ram but needed to be gone through. Well I got the carbs church cleaned so far and now it acres like a banshee ;) still waiting for a few parts that I've ordered online. Previous owner cut off the exhaust and was running no airbox or filter at all.... what an idiot
    .... anyway, so now as I've read on here I'll have to rejet the carbs I have done theath provided and have the correct jets on the way. :D after getting her running I ran her around the block and noticed when I get on it the clutch slips so I have the friction plates and springs on the way too. I saw someone on here that made a xj bobber I'll be doing the same since she's not in perfect shape and I don't have tons of money and its a first bike. Anyway it'll be nice to get some pointers and feedback. Once again its nice to be part of this group thanks a lot guys!
  2. adrian1
    adrian1 Active Member
    Welcome!
  3. RobbieRobot
    RobbieRobot Member
    North Yorkshire, England
    Welcome from England Saltys. You should find all you need to know on here. It's been very helpful to me so far. Keep us posted with your progress.
  4. biggs500
    biggs500 Active Member
    Sherwood WI
    Welcome to the site.
    Here'a a fantastic write up on clutch replacement.
    As noted in the write-up replace the flange bolts too, and not with one from the local hardware store. A torque wrench is critical for this also.
    How are the brakes?
  5. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Welcome! +1 on the brakes. how about the tire date codes as well? check the link in my signature for info on a proper re-comissioning
  6. Saltys
    Saltys New Member
    West Georgia, USA
    Tires are new but I'm sure the brakes are due for an overhaul.
  7. Saltys
    Saltys New Member
    West Georgia, USA
  8. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Welcome to XJBikes Saltys. I would suggest to try and change the oil and filter first before tearing into the clutch. Our XJ's use a wet clutch system which means that you can't use a lot of the new oils which contain friction modifiers which can cause a wet clutch to slip. So for kicks, you can try draining the current oil and install a new filter with new JASO type oil. A motorcycle oil for four strokes like Castrol 4T or Valvoline motorcycle oil works great. Could also use Shell Rotella as well. See if that fixes your problem before tearing into her. Would hate for you to do all the work replacing the clutch and find you still have the problem if you use the wrong oil.
  9. Rayjay1959
    Rayjay1959 Member
    Prescott, az
    2nd on Xjoe550. My clutch slipped a little when I 1st got her. It was only at 7k or above rpm, but it did slip a little. I put valvoline motorcyle oil in her and it cleaned that problem right up. I, too, got lucky and picked up an xj750 for a dime:) $600 ;) and she runs great!!
  10. bigfitz52
    Don't try to talk the guy out of rebuilding his 30-year old clutch; it's an eventuality anyway. You'll be doing it too sooner or later.
    Andrew, be sure you check your valve clearances ASAP. Even though the bike may seem to run better after carb service, the valve clearances were often ignored by POs and they cannot simply be ignored. The clearances tighten with wear and if ignored long enough it will damage the motor.
    Plus it's a prerequisite for doing a carb sync.
  11. Saltys
    Saltys New Member
    West Georgia, USA
    Yesterday I swapped the clutch and springs and it was shot. Thanks forthe oil tip tthough I knew they were wet churches but didn't know u had to use certain oil for this bike. And fitz I'll be doing the valve job soon but for now I can't do anything I gashed my hand open at work last night and can't use my fingers on my right hand ATM. Maybe next weekend when I'm off work and have some scabs built up.
  12. Saltys
    Saltys New Member
    West Georgia, USA
  13. MarkV
    MarkV Member
    Vermont
    welcome Salty. You have made a good move joining this sight, lots and lots of info here. While trying to find info for my project, I stumbled upon it, And I pretty much found all of my answers here.
  14. mtnbikecrazy55
    I have an air box in my garage if you're looking for
    One, just pm me.
    Welcome!!
  15. Saltys
    Saltys New Member
    West Georgia, USA
    Ive been to all my parts stores not seeing any Jaso type oils.....
  16. sektorgaz
    sektorgaz Member
    Western MA, United States
    Castrol 4T 20w50 motorcycle oil is pretty common. Manual calls for 20w40, which is almost impossible to find, so this is a good alternative.
  17. adrian1
  18. MarkV
    MarkV Member
    Vermont
    Salty, just make sure the oil is motorcycle specific.
  19. MarkV
    MarkV Member
    Vermont
  20. XJOE550
    Inverness, FL
    Autozone, Advanced Auto and Walmart all carry the Castrol and Valvoline motorcycle oils. Give one of them a shot. I have picked the Castrol 4T for $2.99 on sale from Autozone in the past.
  21. Maximphilly2texas
    Maximphilly2texas New Member
    Nashville TN
    What jets did you get? Did you have any luck with them. I need to do the same but not sure where/what I'm buying.
  22. Saltys
    Saltys New Member
    West Georgia, USA
    Funny I've been to all of those stores ended up getting a 20w50 generic universal oil. No clutch slipping.. and TeX mymath calls for 126 mains and 41 pilots since 42s don't exist that's with pods and straight pipes
  23. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    The problem with many Universal and Car oils is the additives. They aren't designed for a Wet Clutch, thus we always look for something that states it's specifically for Motorcycles.
  24. Saltys
    Saltys New Member
    West Georgia, USA
    Makes sense but for me I just want to get it running. Not all stores even with the same name carry the same products and every time I order online I end up waiting two weeks
  25. bigfitz52
    All of the auto parts stores listed above carry motorcycle oil in most of their locations; however it's usually not in the same place within the store that the automotive oil is.
  26. Saltys
    Saltys New Member
    West Georgia, USA
    Not to mention I am going to have to do an oil change in 200 miles being it is a brand new clutch because of all the debre that comes off the new clutch. It shouldn't !matter what kind of oil I use this time. I also made sure not to use energy conserving oil which specifically makes abwet clutch slip.
  27. Saltys
    Saltys New Member
    West Georgia, USA
    Thanks fitz maybe that is my problem. However dumb it is that they don't have oil in the oil section is I should have thought of that! And fitz I heard we have a parts guru around here can he run debit/credit cards? And can I get a link to talk to him because before I tear the top end off I'd like to buy all the valve shims and push rods a new clutch gasket and possibly more parts from him when I get off work tomorrow morning. Or this weekend depending on what kind of bill we work up.
  28. sektorgaz
    sektorgaz Member
    PM member chacal or email info@xj4ever.com I think you can use paypal which could be tied to your CC/debit card.
  29. mtnbikecrazy55
    x2, set up a paypal acct with your debit card, works GREAT and is super secure. Len's the man!
  30. Saltys
    Saltys New Member
    West Georgia, USA
    Thanks guys I'll get on that asap.
  31. sektorgaz
    sektorgaz Member
    I wouldn't say it's super secure, but at least you only need to worry about paypal getting hacked/compromised (it happened a few times) instead of mirriad of online retailers having your CC number un-encrypted on their servers.
  32. Saltys
    Saltys New Member
    West Georgia, USA
    Well now papal will let you pay through them with a card so ill never make another account with them had a bad experience with them a few years back. well i got the Castro 4T 20w50 now had to go to orileys in the next town over no one in my town carried motorcycle anything.... orileys didn't even advertise it only hadit behind the counter. but i got it one question i do have is would Lucas oil stabilize be safe to add because of the clutch? has anyone tried it. and off topic i work 12-15 hour shifts all week then my weekend gets here and i have the stuff now its been raining non stop.... fml lol
  33. bigfitz52
    Don't add anything to the oil. Just run proper motorcycle oil.
  34. Saltys
    Saltys New Member
    West Georgia, USA
    OK this fitz. Dry for the lack of posts recently. I've encountered housing issues and the rebuild has been delayed that on top of working from 6pm to 6am makes things a little more difficult
  35. Saltys
    Saltys New Member
    West Georgia, USA
    So put the 126 mains and 41 pilots in and bench synched the carbs yesterday morning this evening before word idles good at 1100rpm. Was stalling out but now its good. Can't wait to get to ride it. I'll be on it all winter I don't care how cold it gets
  36. Maximphilly2texas
    Nashville TN
    . I'm having trouble finding these jets. Did you order them online? If so where did you get them?
