Exhaust and Led Brake Lites on
Discussion in 'XJ Modifications' started by bobcat5540, Sep 15, 2013.
  1. bobcat5540
    bobcat5540 Member
    Mount Sidney,Virginia
    Decided to share some updated pictures of progress on the Ride4Matt.
    BJ Ramirez likes this.
  2. Dano59
    Dano59 Member
    Charleston Illinois
    What seat is that? Modifications to mount it?
  3. bobcat5540
    bobcat5540 Member
    Dano,
    Its off a 2006 HD Fat Bob, (Ebay) 40 bucks. And yea a little modification, removed cover,foam. Cut front out, shaped it added 1/4" machine bolts for attaching the front tongue as the original was and 2 in the back for plate to fasten to frame. Then had it recovered with original foam and cover by upholstery shop. $40.00
  4. bocaj25
    bocaj25 New Member
    San Diego, CA
    Did you have to do any re-jetting with your exhaust like that?
  5. bocaj25
    bocaj25 New Member
    San Diego, CA
  6. bocaj25
    bocaj25 New Member
    San Diego, CA
  7. bobcat5540
    bobcat5540 Member
    Not so far. Have'nt had her on a long of test drive. Still working on the electric's.
  8. bocaj25
    bocaj25 New Member
    San Diego, CA
    I'm thinking about eliminating the H pipe and running four seperate pipes. Do you happen to have any knowledge on this?
  9. Orange-n-Black
    Memphis Area
    My bike had 2 - 2 into 1's without the H when I got it, so don't know about re-jetting. I've heard that a re-jet is required on exhaust mods, but have seen exhaust mods done without re-jetting and no reported problems.
    Jetting for air & exhaust mods aren't always black & white, too many variables like elevation, strength and condition of the motor and humidity. Always best to get the bike in tip-top shape before you mod it.
  10. Rayjay1959
    Rayjay1959 Member
    Prescott, az
    My bike has the idiot light for tail lights. If I put both bulbs in as led's, the draw isn't enough and the light comes on. So, I had to pull 1 and put in a regular bulb. Running 1 of each does save a bit of juice and the idiot light doesn't come on.
  11. bobcat5540
    bobcat5540 Member
    Are you talking about turns or brake? One has to add resistance back to the flasher module for turns to work properly.
    Signal Dynamics corp.has just such a pack that works for these sort of problems. Usually brake lights are not a problem.
  12. bobcat5540
    bobcat5540 Member
  13. bobcat5540
    bobcat5540 Member
    A little more work on the Ride4Matt. Fabricating side covers after looking around on this site for insperation.
  14. bobcat5540
    bobcat5540 Member
    After trial run and color tune, its coming together. Added forward controls and L.H. mirror. Side covers took a little time to get the look I wanted.
    Love the look of a rigid but I like my 50 yr old back the way it is. So I went with the comfort of suspension. Progressive 11" shocks.
    New Brakes front and back with new Lines.
    Overhauled top end ,Bucket shims,rings and any o-ring or seal that was leaking.
    Tank and metal pieces off to get a coat of Hot Rod Black.
  15. bobcat5540
    bobcat5540 Member
    Finished Project of the Ride4Matt. No rejetting,stock air box modified header pipes with Baffel, lowerd with 11" rear shocks. A labor of love.
  16. k-moe
    Nice. I prefer a bike with fenders (even little ones), but the overall look is very good.
  17. XJ550H
    there is a little left of the rear fender;)
  18. Dave Johnson
    Dave Johnson Member
    Oak Grove,Minnesota
    Nice job!
