looking for some trouble shooting ideas
Discussion in 'XJ Technical Chat' started by SilentRaven, Oct 2, 2013.
  1. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    ok so i got the bike all back together recently and just tried firing it up today but all i got was the engine cranking over it never wanted to fire.
    things i checked...
    battery is fully charged
    fuel is going to carbs
    choke is set correctly
    oil level seems fine
    things ive done recently...
    cleaned carbs
    reset float levels
    installed fuel filter
    new float needles
    new seats and o-rings
  2. Proximal
    Proximal Member
    ATL, Ga
    Check for spark?
  3. sektorgaz
    sektorgaz Member
    Western MA, United States
    Did you fill up the float bowls by running the petcock on prime first?
  4. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    didnt check for spark ass i had to recharge the battery after so many attempts, but will do that next.
    Yes i primed the carbs, still no kick over
  5. Proximal
    Proximal Member
    ATL, Ga
    Try spraying some starter fluid into the airbox. If that doesn't get it going, you are probably not getting any spark. If it does start, you've probably got a fuel delivery issue.
    I'm no guru though...
  6. MiCarl
    I thought so too.
    I've got a fuel injected ATV in the shop that didn't run. Fired up on starter fluid.
    During testing of the injector system it started running, but then quit later. I decided it was a bad injector. Replaced the injector and it still didn't run. Turned out to be a flaky spark plug.
    With a new plug the old injector works just fine.
  7. bigfitz52
    I was going to suggest a new set of properly gapped NGK D8EA plugs.
    Unless, like me recently, you have the TCI unplugged and forgot to plug it back in...
  8. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    Thanks all, I did fire right up after I left the battery in the charger for about an hour, I guess it didnt have quite enough power to start it up. And thanks to teddytedted got my idle properly set and its running great. Now just need to take it for a test ride!
  9. luvmy40
    luvmy40 Member
    Y-Town, OH
    I see the problem was a weak battery but food for thought; After sitting for the better part of a year, The '81 Seca that I gave to my son would not start. I unplugged and re connected the "ignitor" box and she fired right up.
  10. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Nice. Glad to see that it's not just me and I don't have the market cornered on bonehead moves like that.
