Seca 750 forks - 81 to 83 compatability
Discussion in 'XJ Technical Chat' started by EmPdub, Sep 30, 2013.
  1. EmPdub
    EmPdub New Member
    Vancouver,BC
    Hi all, new to this board and new to the motorcycle scene in general.
    My first bike is an 83 750 Seca which I picked up from my electrician pretty cheap. The forks are fairly pitted and cause some leaking and the suggestions so far have been to replace the forks or have them ground out and hard chromed again.
    Scoping the online parts, I see forks described as 81-83, 81 and 83. My question is, are the forks from these years' 750 Seca interchangeable?
    Cheers
  2. chacal
    Yes, all 1981-83 XJ750 Seca forks are the same!
  3. EmPdub
    EmPdub New Member
    Vancouver,BC
    Sweet. Thanks. I now have direction for my winter project
  4. luvmy40
    luvmy40 Member
    Y-Town, OH
    I have an extra set of complete fork tubes(no triple clamps). They came off of my sons, '82 Seca 750. They're in pretty good shape but they've been sitting unused for a year or two now. Probably need seals and certainly will need fresh oil.
  5. EmPdub
    EmPdub New Member
    Vancouver,BC
    Hi Luvmy40,
    Sent PM. Interested.
  6. kinen1
    kinen1 Member
    Perth, Western Australia
    hi all,
    while we r on this topic. I have got an 83 xj750 (Australian delivered & sticked 750) but it's got XJ900 frame, fairings, wheels front and back are both disc brake! it's got the YICS.
    What i would like to know is. Are there any Seca or Maxim out there that has got the same forks (37mm dia) As i would like to change the ugly 2 piece cruising handle bars. In order for me to do this I have to change the Top Triple clamp! So if any one out here has got a 37mm dia forks please state ur year and model so i can hunt some down on ebay......
    I will post pics once i find some!
    thank you all
    kinen1 :)
  7. kinen1
    kinen1 Member
    here is the pic of the top triple clamp.
    edited with pic!
    it's the groove where the handle goes that I don't want. :(
    kinen1
  8. kinen1
    kinen1 Member
    here is the pic with the 2 piece handle bar.
    edited to add pic.
    this is the original handle bar.
    kinen1
  9. quebecois59
    NOt sure, but I don't think you'd have to change the whole forks to put new bars. You just need to put some bar risers then standard round-section handlebars.
  10. TIMEtoRIDE
    Hey there !
    What you have is a SECA 900 "chassis" with a 750 motor, and "Regular" SECA 750 fork parts aren't gonna work. (not MAXIM either)
    You need to scour Europe and Australia's E-Bay for a "top triple tree" that accomodates a regular chrome handlebar. Make sure the fork tube diameter are EXACTLY the same with the seller.
    Shouldn't be that hard to find.
  11. Bushy
    Bushy Active Member
    Hello kinen1, sounds to me like you've got a 750 RL model, put that in the google machine and you'll find plenty of info, probly unusual carbs too.
  12. kinen1
    kinen1 Member
    that is the road i wanna go down..... I just hope i can find some!
    thank you quebecois59.
  13. kinen1
    kinen1 Member
    hey TIMEtoRIDE,
    1984 XJ750 RL only made in 84' and only 884 ever made 601 of them shipped to Canada and the rest to Australia...... (i got that on the net) hmmm..... i don't know if that is a good thing or bad! lolz. :eek:
    I am looking at cafe racer or fighter it not sure which yet..... I will post it in the XJ MOD once i get started. Just to go get this Top triple clamp sorted!
    Now that I have found a bit more info on it. I am not sure if i wanna mod it.... I may do a full restored!
    I have an 81 XJ 650 R I can work on!
    thanks for the info mate. :roll:
    kinen1
  14. kinen1
    kinen1 Member
    Hi Bushy,
    Will have to google it!
    what do u mean by unusual carb???? 8O 8O 8O
    kinen1
  15. TIMEtoRIDE
    The jetting is "non-USA" most likely, and the intake airbox-to-carb boots are unique, , , and should not be lost or destroyed.
    You have a rare, low production # XJ and it should remain "stock"
    You could "cafe" any other bike, but not a rare one.
  16. Bushy
    Bushy Active Member
