Wet Set...Can Somebody Check My Work?
Discussion in 'XJ Technical Chat' started by patmac6075, Nov 23, 2013.
  1. patmac6075
    patmac6075 Active Member
    MKE
    Ok...Carbs have been pulled, completely disassembled, dipped, rebuilt with new seals and o-rings, and bench sync'd.
    So I built this contraption to hold the rack level in all directions while I filled the float bowl with gasoline:
    These next two pictures are pretty representative of all four carbs:
    The bottom of the "bubble" is just a shade below bottom of the carb body...suprisingly enough...all four were almost spot on the first time around...the dry set really helped.
    So do I pass?
  2. TECHLINETOM
    TECHLINETOM Member
    Deerfield OH
    looks good depending on where it is supposed to be.
    On my XJ1100 that would be a little high but it is really close.
    Good Job!
  3. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    You only pass if your fuel levels are all the same and in spec...
    You need to know what your fuel levels need to be set at then measure them below the edge of the carb body like your doing. But you will need something to measure with. If you did measure with a proper gauge then you should be good. But if it's by eye then I would get a gauge or the carbs may have to come back off and this will need to be done again.
  4. schmuckaholic
    California
    750 carbs are supposed to be set at 3mm +/- 1mm. The fuel level we're seeing is right at the edge of the carb body, which means it's way the hell high. The float tang needs to be bent up a wee bit to lower the fuel level in the bowl.
  5. RickCoMatic
    This illustration shows where the meniscus of the Fuel in the Clear Tube should be when you are within specs.
    You need to be within the yellow or green.
    Anything ABOVE the top of the Lock Washer if too High.
    ::: Float Height Limits ::: Yamaha Publications ::: Factory Manual :::
    Green = Ideal
    Yellow = Acceptable
    Red (lower) = Fuel Starvation possible.
    Red (higher) = Flooding possible.
  6. bigfitz52
    There you have it. Granted, the angle of the photos may be throwing us off a tad, but they look high to me too. See Rick's diagram; personally I found the marked tube to be a PIA so I use a fine sharpie and put a precisely-measured mark on the carb bowls. Either method (graduated tube or a mark on the carbs) will work; but it's really hard to accurately "eyeball" 3mm to within 1mm either way.
    This may help: http://www.xj4ever.com/setting%20fuel%20levels.pdf
  7. patmac6075
    MKE
    So, there you have it....back to the lab!
    Fitz....the pictures don't lie...I was under the, false, impression that the ideal float height was even with the carb body....not sure where I came up with that because I've read and reread as much as I could :oops:
    Thanks to all that weighed in!
    Will repost once carbs are readjusted.
  8. patmac6075
    MKE
  9. bigfitz52
    RE: adjusting. Remember if you bend the tang enough to know you bent it you probably went too far. Think "nudge" or "tweak."
    Also check the other little tab that forms the "downstop" for the float to ensure the floats don't go "over-center" and hang up when the bowls are empty.
  10. Polock
    that's about where mine are set, never found it to be a big deal......but, is that fuel line full? looks like a big bubble or somethings not right.
    the bowls might not be full yet
  11. 750E-II_29Rbloke
    South Cheshire, UK
    Huh? where's the bubble? :?
  12. patmac6075
    MKE
    Should be pretty accurate...I had "exercised" the float pins before I took pictures. (Fill/empty/run through/fill/empty/fill/check reading)
    If the bubble you see is in the first/top picture, that was taken during my leak test...you can see that the petcock, in that picture, is closed.
  13. Polock
    third picture, is the fuel line full or empty
  14. patmac6075
    MKE
    Third pic...fuel line is full...perhaps what you're seeing is the top of the "checker" line which has gone over the top of the carb rack and curled back around behind the main fuel line...perhaps that is the bubble you see...either way...I don't think there were any bubble during testing...
    As always...your input is appreciated!
  15. xjdaver
    xjdaver Member
    Medford, Wisconsin
    I probably would have toppled the carbs off the stack of cardboard boxes a few times with that set up. but hey, that's just me.
    Is that a sew-up tire?
  16. 750E-II_29Rbloke
    South Cheshire, UK
    Same here actually lol :lol:
    And well spotted, yes I believe there's a "tub" hanging to the right of the rack. All well and good til you go down a long hill & melt the glue! 8O
  17. patmac6075
    MKE
    Ha ha...yes it is a sew-up (former bicycle mechanic here...I'm sometimes amazed how much '80's Japanese used cross engineering...so much is so similar...without the engine of course)
    The carbs are not balanced on the boxes...I built this contraption...but the rubber reducer cannot handle the full weight of the carbs, so the boxes and miscellaneous hunks of metal are a kind of support structure as well as a leveling device...an engineer, I AM NOT!!
