dead cylinder
Discussion in 'XJ Technical Chat' started by davec, Dec 4, 2013.
  1. davec
    davec Member
    ontario canada
    sold my xj 700 we became friends, dude was in behind him said big puff black smoke from right side.. i was there tonight, all 3 pipes are hot,, 4th pipe i wrapped hand around,, its cold.. dead cylinder, she was runnin fine before, dropped a cylinder,, i checked spark,,its getting sprk from plug wire to spark plug when turned over any clue guys? i was thinkin coil,,but theres spark, #4 cylinders dead,. wet spark,, cold,,,
  2. davec
    davec Member
    ontario canada
    i should add theres no white or blue smoke.
  3. adrian1
    adrian1 Active Member
    Compression?
  4. bigfitz52
    Yeah, start there. Do a compression test; un-compressed mixture won't light.
  5. 750E-II_29Rbloke
    South Cheshire, UK
    And while the plugs are out for the test, throw them away & fit new ones.
    Modern fuel isn't kind to plugs and they can appear to spark fine when "tested" against the side of the head at atmospheric pressure and with no mixture to ignite, but can break down and stop sparking once they are under compression & surrounded by fuel/air mix.
    Added to the fact they're dirt cheap, they may as well be ruled out straight away. (also make sure they're the correct kind, non-resistor type with resistor plug caps and vice-versa)
  6. davec
    davec Member
    ontario canada
    he doesnt have a comp tester, but its cold pipe,,all other 3 i couldnt even touch,
  7. davec
    davec Member
    ontario canada
    i told him dont even start it anymore and to drain oil and check for metal filings,
  8. davec
    davec Member
    ontario canada
    i feel bad for the guy,,
  9. davec
    davec Member
    ontario canada
    you guys know this bike,,i complained enuff all season lol..i got it runnin good,,then i sell it and it blows up,,
  10. beazy22
    beazy22 Member
    WI
    sounds like you got rid of it just in time
  11. davec
    davec Member
    ontario canada
    lookin for a cause here always a reason,
  12. bigfitz52
    I'm sure there are auto parts stores in Canada that "loan" or rent tools just like here in the States. Or buy one, it's a whole $25 investment.
    If it dropped a valve or holed a piston it won't produce a combustible "charge." No fire = no heat. Many possibilities for no fire.
    If the compression is good then you start looking for other causes.
    DON'T ASSUME. DIAGNOSE.
    Obviously that cylinder isn't firing. There could be any number of reasons for that, but to diagnose it you have to go in order. And that begins with making sure it can actually produce compression in that cylinder. If it CAN, then you move to the next step. If not, then cry the blues.
  13. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Where are you in Ontario? I could help you if your close.
  14. Polock
    Just take the plug out and hold your thumb on the hole.
    Crank it over a few times and see if you can hold back the compression.
  15. bigfitz52
    That "kinda" works; except 45psi will quickly pop your thumb out of the hole but anything less than about 60psi ain't gonna fire.
  16. Polock
    How do you make 10 psi with a valve that don't work or a hole in in the piston
  17. davec
    davec Member
    ontario canada
    ok talked to buddy, hes gunna rent a comp tester,,but thumb over hole could sorta be a good easy step for now,, but i know earlier this season the comp was 4 psi off stock,
  18. davec
    davec Member
    ontario canada
    im in kitchener btw
  19. davec
    davec Member
    ontario canada
    ok he just did that thumb test,, he said his thumb got blown off the hole np,
  20. bigfitz52
    As Polock pointed out, a cylinder with a dumped valve or holed piston won't; however a BURNT valve (or other compression-reducing situation) may still cause low enough compression for no combustion, even if it does pop your thumb off the hole.
    My point being, the "thumb on the hole" test is NOT necessarily proof of enough compression for combustion to occur.
  21. davec
    davec Member
    ontario canada
    rgr that,, we are gonna rent a comp tester..gunna make sure,, but at least its not a blown piston, (phew), its gotta be valve spring or stuck valve,,but if its a valve stuck,,how would we get a proper reading anyways?
  22. bigfitz52
    You won't. But then you'll have a better idea of what's going on.
    Based on the results of the first test, you might want to follow up with a "wet" compression test.
  23. Polock
    send your rental bill to Fitz
  24. TIMEtoRIDE
    You can actually SEE the valves thru the plug holes, if you look carefully.
    That would rule out the dropped valve, and the holed piston.
    But you could crank it - IGN off - by crossing the solenoid and HEAR the engine hit compression evenly, or - - 3 hits and a quicker spin.
    But seriously, get a real compression gauge.
  25. davec
    davec Member
    ontario canada
    its knocking. sprk to plug,, dead cylinder guys,,,thats all i know,,
  26. bigfitz52
    But that's all we know.
    I guess it depends on whether or not you're serious about figuring out what happened and what it might take to fix it. If you are then the first steps are dry and wet compression tests. Then you will probably need to pull the head. But if you just pull the head, you've missed the opportunity to get valuable information about the condition of the cylinders, including the good ones. Information that could prove to be very valuable in the upper-end rebuild decision making process. Figuring out exactly what broke will certainly influence the "repair vs. replace the motor" decision as well.
    Polock, the way most tool "rentals" work around here, you get 100% of your deposit back when you return the tool, so it is essentially free of charge.
  27. davec
    davec Member
    ontario canada
    my next post will be #s quite serious about fixing this and want to learn why,
  28. sektorgaz
    sektorgaz Member
    Western MA, United States
    Did you send the Fitz' check over?
