new speedo and tacho ?
Discussion in 'XJ Modifications' started by willem, Dec 14, 2013.
  1. willem
    willem New Member
    holland
  2. Polock
    the ones from China have some questions, the speedo uses a cable, your yamaha cable i guess. does your cable fit the speedo and is 60kph=1400 rpm.
    on your bike? the tach, says nothing about 1,2 3 or 4 cylinder engines, that might not be a problem or it might read rpm times two or half rpm's.
    i think i've seen guys on here use the one from the UK successfully
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    the bottom link is a very good price, as equivelent acewell ones are above £100.
    i'd like to know if anyone has fitted one ,as a wiring diagram would be helpfull.
    17" wheels would be a problem though as mine are 18", unless its programable for different sizes?
    stu
  4. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Ive used the bottom one.
    Doesnt work.
    Well it did for 30 miles
  5. willem
    willem New Member
    holland
    so this stuff wont work what will do for low money budget please some links if you got some thanks.
    greets :lol:
  6. Polock
    i have a acewell, it's worked fine for 4+ years. works with any size wheel any # of cylinders
  7. bensalf
    yorkshire ,england
    the bottom link looks remarkably like the koso one below.
    wonder if its an exact copy.
    koso one is $109!!
    stu
  8. willem
    willem New Member
    holland
    whats gonna happen if i used meters from another bike.
    it has to be from a bike that has a 19 inch front wheel i think or is it plug and play from doesnt matter from wich bike?
    greets :lol:
  9. Polock
    the other one goes to 22000 rpm.....wow
  10. bensalf
    yorkshire ,england
    no ,the specific bike ones will be made for that bike,the number of cylinders will dictate the rpm display.
    some have gearbox sensors for speedo.
    it may be possible to transpose some types, but you would need a good wiring diagram for each bike , and be prepared to spend some hours figuring out the swopping of the wires.
    stu
  11. bensalf
    yorkshire ,england
    oh yeh,! did'nt notice that. :?
    stu
  12. k-moe
    The one the OP linked is a crappy copy. Based on reports from some of the scooter forums, the copies tend to be inaccurate when new, break (also when new), and generally suck a$$. The KOSO gauges are OEM parts for Brammo, and a few other small motorcycle manufacturers. I saw KOSO gauges as OEM on something from the big 4 recently, but I can't remember which model.
  13. willem
    willem New Member
    holland
    found a used speedo and tacho from a yamaha sr500 mechanically
    will this be working on my xj550
    greets :lol:
  14. willem
    willem New Member
    holland
    forgot the photo
    greets :lol:
  15. bensalf
    yorkshire ,england
    ithink the yamaha sr is a twin cylinder, if its an electronic tacho it may only read half the revs.
    stu
  16. bensalf
    yorkshire ,england
    sorry sr is a single, your tacho may read 2 or 4 times more
    stu
  17. bigfitz52
    No no no.
    The bikes are 4-strokes. A mechanical tach, coming off the camshaft, will have the same relationship, RPM-wise to the crankshaft regardless of the number of cylinders. Four-stroke camshafts turn at half crank speed regardless of the number of cylinders.
    The SR500 has a mechanical tach. It will work; there's only a minor issue: the XJ550 redlines at 10K. The SR tach will spend a lot of its time "wound tight." The whole XJ "fun zone" is red on the SR tach. The XJ650R (and Euro-spec XJ650, not the Max) had a simple, "canned" tach like that too, but with a more "XJ-friendly" redline. Use the SR tach for now, and keep your eyes open for one from an XJ650.
    The speedo should work fine. In regard to speedometers, virtually all Jap bikes from the mid-late '70s right up into the '90s with mechanical speedometers have the same drive ratio, so you can even swap between most manufacturers and have them work fine (as long as the bikes have the same size front wheel.) Then again, virtually all Jap bikes of the era over about 500cc had 19" front wheels.
    Those clocks should work fine (other than torturing the tach.) And of course, provided they aren't gummed up or in need of attention themselves. http://xjbikes.com/Forums/viewtopic/t=15303.html
    Might want to have a peek at this too: http://xjbikes.com/Forums/viewtopic/t=19538.html
  18. willem
    willem New Member
    holland
    I did buy the set from the pic above they are both mechanic build them in my old housing and they work great thanks guys for all the info.
    greetings :lol:
  19. willem
    willem New Member
    holland
    Thanks a lot did buy the set and it works great.
  20. bigfitz52
    In your old housing? Why didn't you say so? I thought you were getting rid of the stock cluster. Would have made it even easier...
    In the States, we got 85mph speedometers. THAT had to go:
