Fork Seals
Discussion in 'XJ Technical Chat' started by nammy, Jun 6, 2007.
  1. nammy
    nammy Member
    Upstate New York
    Looking for fork seals kit for 85 maxim X.
    Any suggestion where to buy? Best Price?
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    I have found out that the dealer has better fork seals at not too high a price.
  3. samsr
    samsr Member
    Colorado Springs
    The best ones I have found are at the dealer. Most of the aftermarket ones are 2 to 3 mm shorter than the Yamaha ones. This doesn't sound like much difference but when you are dealing with a hydrolic seal, yes hydrolic seal, Every mm makes a difference. Pop for the Yamaha ones.
  4. XJoregonian
    XJoregonian Member
    Oregon, US
    I got a pair off of ebay as well........worked well and the price was right!
    Just my two cents.
  5. thefreeauction
    thefreeauction New Member
    Cold Nebraska
    I just got my fork seals for my '81 550 from ebay last week, they are "Pyramid" brand. I haven't put them in yet. They were $14.50 shipped. I don't know how good of quality they really are (first time replacing fork seals), so I can't really help in that area.
  6. nammy
    nammy Member
    Upstate New York
    thanks for the help guys.:)
  7. dinoracer
    dinoracer Member
    Chattanooga, TN
    for the few extra bucks it cost from the factory vs. you doing the labor for X brand if they do not work.. Um I would shell out the few extra bucks for the factory ones, not worth my time going to unknown or untested seals
    Sean
  8. mr_ex
    mr_ex Member
    maine usa
    im in the process of doing my seals.....gonna try a set of k&s off fleabay :oops: ill let yuz know how they perform.
    found a easy way to get the forks apart....with a 3/4 inch square stock of wood...pefect fit :wink:
  9. nammy
    nammy Member
    Upstate New York
    I'll be doing mine next week.
  10. MAX-X
    MAX-X Member
    Ohio
    For me,
    Factory seals + Progressive springs = :D
    Handles much better than before!
  11. triump
    triump Member
    Mississauga, Ontario
    where did you get the progressive springs?
  12. MAX-X
    MAX-X Member
    Ohio
    Triump,
    I got them from Bike Bandit, $64.00 plus shipping. Not a bad deal & bike handles much better :D
  13. triump
    triump Member
    Thanks.
    Been thinking about getting some.
  14. RickCoMatic
    Nice move coming-up with that wood Fork Tool.
    I'm nominating you for "Shade-tree Wrencher of the Month"
    Here's a tip you can use if the Oil Lock Piece is looking a little beat.
    Using some Standard, water-based, Valve Lapping Compound ... you can "Lap" the Oil Lock Piece at the end of the Damper Rod. Since the Oil Lock Piece is soft, to begin with ... it only takes a few seconds of Lapping-it-in with just your fingers moving it around and back on the Damper.
  15. mr_ex
    mr_ex Member
    maine usa
    awwwwww :oops: twernt nuthin :oops: :oops:
