Front Forks Clean-up
Discussion in 'XJ Technical Chat' started by cdnjj, Jan 6, 2014.
  1. cdnjj
    cdnjj Member
    Vancouver, BC
    OK, I'm contemplating adding to my to do list as I'm mid-way through replacing the steering bearings and a few other things and waiting for parts.
    While I have the forks off I'm thinking of cleaning up the fork lowers, they are pretty ugly. Not looking to get to showroom or anything too shiny, just presentable.
    A nice satin finish would be fine. Any better suggestions than this write up?
    http://kawtriple.com/mraxl/tips/forkres ... ration.htm
    I was thinking of going with paint stripper (vs blasting) and skipping the clear coat at the end.
  2. RickCoMatic
    I stripped and sanded my fork lowers before polishing them with buffing wheels and jewelers rouges.
    Sanding them out for polishing was performed with a pneumatic D/A. Air powered "Dual-action" sander makes the pre-polishing prep with 400, 600, 800, 1000 and 1200 quick and easy!
  3. bigfitz52
    Sounds like a plan. Virtually all of the "polished" alloy on my bikes has been stripped, sanded/polished; and then just kept shiny with the occasional polishing.
    Aircraft Paint Remover works better than any other method for completely removing the original clear coat.
  4. moellear
    moellear Member
    Lima, Ohio
    +1 on the aircraft paint remover. I had to special order it at an automotive store (can't remember which one) & the spray can is expensive but well worth it. FYI you don't wanna touch it with your bare hands.
  5. cdnjj
    cdnjj Member
    Vancouver, BC
    Awesome, thanks. I'll give it a shot this weekend.
