Need a reference!!!!!
Discussion in 'XJ Technical Chat' started by mastermin144, Jan 29, 2013.
  1. mastermin144
    mastermin144 New Member
    Does anyone know a custom head gasket company in california that can manufacture from a paper schematic? i have a few listed in mind, just wondering if anyone has had a good experience worth mentioning.
    Also, is anyone in need of this head gasket 1FG-11181-00-00,
    trying to have a few made if more than a couple of ppl need them. very rare and impossible to find.
  2. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
  3. MiGhost
    MiGhost Well-Known Member
    A suitable replacement, and still available.
    XJ750 head gasket.
    5G2-11181-10-00
    Ghost
  4. japcrap
    japcrap New Member
    alaska
    700 and 750 DO NOT have the same bore size.
  5. k-moe
    Actually.....
    From Len's catalog (and Len knows almost everything):
    HCP4670 OEM cylinder HEAD GASKET, fits between the head and the cylinder jugs, for all XJ700 non-X (air-cooled) engines. Use 1 per engine. NOTE: XJ700 air-cooled owners can fit the XJ750 air-cooled engine head gasket (HCP4671) to their engines to achieve a lower compression ratio, as the XJ750 head gasket is approximately 0.15mm thicker than the XJ700 engine head gasket.
    $ discontinued
    The water cooled XJ700X does indeed have a different bore size from the XJ750, but the XJ700 (non-X) shares the same size bore as the XJ750 (65mm). The part number given by the OP is for the air cooled XJ700 head gasket.
  6. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    OP should post what bike they have instead of just a part number.
    That way they would get much better service from this group . . .
    Just sayin'. :?
