the ad says "good working order"
Discussion in 'Hangout Lounge' started by FtUp, Jan 21, 2014.
  1. FtUp
    FtUp Well-Known Member
    pacific northwest
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Good working order is in eye of the beholder.
  3. pnthubb
    pnthubb Member
    San Diego
    You guys don't think that it is all just "cosmetic?" :roll:
  4. z32800
    z32800 Member
    Wellington New Zealand
    A good dremel and there good to go surely!!! :)
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Maybe should have said "re-buildable". If there are no broken post, no stripped holes and no holes in the bodies the rest can be replaced. Break the rack, couple days in Evaporust (I'm sold on the stuff), lemon juice boil and a parts order to Len should make a decent rack. I'd give $50 for the lot.
    Roc
  6. dmlyster
    dmlyster Member
    Corvallis, Oregon
    much work / rebuild, then 'maybe' it'll be functional. good luck but I wouldn't touch em.
  7. FtUp
    pacific northwest
    that parts order will run you around $250-300. ad that to the purchase price and then you will have a set of carbs in "good working order".
    CN
  8. rocs82650
    Middle Tennessee
    cyclenoob,
    You're probably right. I was just saying that members here can rebuild that rack to actual "good working order". Most of us know the "hat trick" to these bikes is to learn how and keep the carbs set up correctly. Also, most of us wouldn't buy that rack as a primary unless we unknowingly bought a bike with a non-stock rack on it and a WTB thread didn't turn one up which it probably would. I said I'd give $50 for it. 50 bones for a parts rack...I'd do it.
    Roc
  9. FtUp
    pacific northwest
    agreed. ads like this can be very misleading. as it is written, the buyer has no idea what they are actually buying, and the seller seems to be in the same boat.
    CN
  10. solcoco
    solcoco New Member
    FL
    In the case of my bike, when I drove over to the PO's house, "good working order" apparently applied when a battery was actually IN the bike. Not to mention the fact that he had to give her a running start for 6 house lengths down the street. In flip flops. Not that flip flops have to do anything with "good working order."
