Inside of your helmet cleaning.
Discussion in 'Hangout Lounge' started by KrS14, Jan 28, 2014.
  1. KrS14
    KrS14 Active Member
    St Marys, Ontario
    So what do you guys do to, clean the inside of your helmet from sweat etc.?
    Febreeze?
  2. lacucaracha
    lacucaracha Member
    Napa, CA
    Don't use febreeze! Its highly carcinogenic!
    Use baby shampoo. If you have a removable liner it makes it way easier. If you don't, just kinda blot it, and go back in with a wet cloth to try to sop it back up.
    The trick it not using anything too harsh since it can break down the liner or safety materials if it has the wrong chemistry.
    Gentler the better, and just set it out to dry. If you're impatient use the heater vent or similar, just not too hot.
  3. k-moe
  4. bigfitz52
    Exactly. If it's a halfway decent helmet, the padding and liner snap out and can be washed/scrubbed/dried etc; GENTLY.
    Not just baby shampoo, but ANY shampoo, diluted, can be used to clean the liner. My logic has always been "what do I use to wash my hair?" Certainly not Fabreeze. EWWW.
  5. FtUp
    FtUp Well-Known Member
    pacific northwest
  6. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Apparently the EWG found it to be quite bad, google will help if you want to know more.
    Keep the ideas coming, I've never heard of a way to do this.
  7. lacucaracha
    lacucaracha Member
    Napa, CA
  8. bigfitz52
    I got the shampoo idea from riding motorcycles for 45+ years. Helmets can get stanky.
    Here's another little tip: shampoo makes a great impromptu roadside hand cleaner if you've just had to change a chain-lube soaked rear tire and didn't think to bring a proper hand cleaner with you on the trip. Rub it in good and go find a nice water-filled ditch; clean hands in no time. Clean enough to put your gloves back on anyway.
  9. TIMEtoRIDE
    From the Venture forums, put the helmet in a CLEAN dishwasher with shampoo. Don't use the drying cycle, of course.
    Water temp 130* around 40 min wash cycle.
    Done this six times now, and my liner hasn't fallen apart. Helmet comes out smelling really fresh, too.
  10. painter
    painter Active Member
    Sevierville Tn
    anybody wear doo rags? They help keep the helmet clean longer. They are comfy to when you are bald like me!
  11. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    That's pretty dubious.
    1) the study wasn't independent, but commissioned by a biased group.
    2) the "contaminants" are not listed by density or volumne, which actually defines if it's dangerous or not, but by "Number of contaminants". There's radiation all around us, but only at high doses does it pose a problem. Saying "Product A has 5x as many contaminants than Product B" is meaningless if everything is well below toxicity levels.
    3) There's also no mention of decay. Chemicals that have toxicity in vapor form have a time line of how long that toxicity lasts, usually under a minute and only in, as pointed out above, certain densities.
    I'm not throwing that one out, but we need a lot of corroboration before I can accept those findings.
  12. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Sweet! Thanks for the suggestions guys!
  13. k-moe
    The effects of a chemical are always dependant on the dosage. I'm not saying that any cleaner is of no concern, but so much of what is reported as being harmful isn't harmful at all when typical levels of exposure are accounted for. I eat formaldehyde on a regular basis, and from an organic source to boot, but not in amounts that are harmful.
  14. mtnbikecrazy55
    Febreeze, nastyyyy.
    Dishwasher idea is pretty nifty. I hadn't thought of it really, but what could be different than riding in a rainstorm with the face shield up?
    Only problem is, I don't have a dishwasher...
    So I suppose pulling the liner and hand washing works too :)
  15. murray
    murray Member
    Sydney Australia
    .... And to add to Fitz,s advice , if you grab a handful of sand or coarse dirt mixed in with the shampoo ( or dish washing liquid in my case ) , it makes a very good impromtu hand scrub, cheers , Murray
  16. hogfiddles
  17. k-moe
    OMG it has ethanol in it. I once got in a fistfight with a really good friend because of that stuff.
  18. TIMEtoRIDE
    . . . so, who got the last beer ?? :p
  19. Polock
    maybe this year i'll try a little spritz of this stuff to freshen things up
