DIY powder coating
Discussion in 'Hangout Lounge' started by FtUp, Feb 6, 2014.
  1. FtUp
    FtUp Well-Known Member
    pacific northwest
    has anyone here done it? what equipment did you use? what was your experience? do you have any tips or tricks for better results? I have been watching you tube videos and it looks like a no brainer.
    CN
  2. k-moe
    I haven't done it personally, but I did watch my father powdercoat some machinists hammers. Don't bake the coating in the house. Get a used oven, or do the baking on an outdoor grill. Much trouble will be avoided by taking this advice.
  3. adrian1
    adrian1 Active Member
    "Much trouble will be avoided by taking this advice"
    You obviously speak from experience! :) :)
  4. z32800
    z32800 Member
    Wellington New Zealand
    Hey CN, I sell powder coatings here in NZ and primarily its applied with an electrostatic gun which charges the powder and the steel is earthed so the powder is wrapped around evenly; thats gunna be the tricky bit (Application) you will then need to bake it at 180 degrees for approx 10 minutes, and Im with K-moe dont do it inside. Wet paint is easier and more accessable.
  5. FtUp
    pacific northwest
    I just picked up a free oven of craigslist this afternoon. ultimately I will build a bigger box to put the heating elements and controller on. ultimately I want to be able to coat wheels, both for bikes and cars. I am also considering coating my fuel tank that I am restoring. but for now the oven will do as it is. I want to do the brake master cylinder and calipers.
    CN
  6. Kornbread
    Kornbread New Member
    ohio
    I have been doing powder coating for about 8 years now. I have a DIY set up from Eastwood. Its pretty easy, just follow the directions on their bottle as far as temp goes. One thing I did learn is that small or thin parts heat up much much quicker, so as soon as they are "flowed out" I generally remove them. As with paint prep is everything. Powder coat is a little more forgiving than paint but it will still show. I sandblast everything, pre-bake, let cool, then coat and bake. Let cool and bolt it back on!
  7. schmuckaholic
    California
    I tried using Len's aerosol coating and a toaster oven on some caliper pieces. The procedure was pretty straightforward, except the aerosol coating didn't come out silver like it was supposed to.
    Just out of curiosity, what would the approximate equipment costs be for doing it the standard way, with the electrostatic gun and what not? And I trust this works with aluminum as well?
    Quoted for truth.
  8. FtUp
    pacific northwest
    I got my new (free) convection oven hooked up and working.
    oven by bmonkey36, on Flickr
    ready to bake by bmonkey36, on Flickr
    this oven is so clean I would use it in my home if I needed one. it will be the perfect donor for a custom oven.
    I also picked up this powder coating gun new in the box off craigslist today at a decent discount. it also came with 2 bottles of the black powder that hf has.
    http://www.harborfreight.com/10-30-psi- ... 94244.html
    so far I am out $50 and I am ready to powder coat. that being said, I already have a sandblast cabinet and pressure pot blaster. which is kind of essential to getting good results with powder coating.
    I almost forgot, I will have to get some high temp masking tape and some silicone rubber plugs, so there will be a small investment there as well.
    CN
  9. FtUp
    pacific northwest
    my high temp plugs, caps and tape came today. the green tape is actually sand blast resist. the high temp tape comes in the next installment....
    all plugged up 1 by bmonkey36, on Flickr
    all plugged up 2 by bmonkey36, on Flickr
    blasted by bmonkey36, on Flickr
    now I have to improvise a spray booth and I am set to coat my first carb.
    CN
  10. k-moe
    Make sure the you don't podwercoat anything that sits inside of the float bowl, or the diaphragm house. Including the gasket surfaces.
  11. FtUp
    pacific northwest
    yup, already planning to mask those areas before coating.
    CN
  12. k-moe
    I figured that you planeed to, but I have failed to do far too many things that I planned to do.....lol
  13. FtUp
    pacific northwest
    even the best laid plans of mice and men...
    powder coated 1
    what little powder ended up inside the float bowl area is no concern to me. I am amazed at the quality of the finish.
    FU
  14. bendoza
    bendoza Member
    portland, or
    looks very nice. i'm in need of something like this.
  15. mtnbikecrazy55
    looks great man!
  16. FtUp
    pacific northwest
    so far I have spent $110 on equipment. that number will go up when I build my larger oven, not sure just how much yet though. hopefully under $100.
    FU
  17. Polock
    Why didn't you put the float bowls on? Different color?
  18. FtUp
    pacific northwest
    this is just my very first (test) piece. the rest of the carbs and the bowls are next.
    FU
  19. cg82
    cg82 Member
    Rossland British Columbia
    I have also recently ventured into the world of powdercoating. I did my caliper and will be doing my levers and a few other pieces. its pretty awesome. I have got pics of my caliper in my build thread if your interested in seeing it.
  20. FtUp
    pacific northwest
    your caliper was the inspiration to get into it myself. meaning, it's all your fault! lol. I am currently waiting for my first order of custom powders. there is definitely going to be a lot of black chrome on my bike. maybe even with a blue pearl clear coat over it too.
    FU
  21. cg82
    cg82 Member
    yeah, there are so many awesome colors out there. check out http://www.prismaticpowders.com/ i have yet to order there myself but there are some amazing colors. I do have a chrome and a translucent blue that goes over the chrome but so far I have had a hard time getting the top coat to stick over the chrome. Even tried a clear coat over the chrome and was unable to get it to stick evenly. Lots of tricks to this trade as I have found out reading up on my problems.
  22. FtUp
    pacific northwest
    interesting. did you see this in prismatic powders knowledge base?
    http://www.prismaticpowders.com/resourc ... estion/79/
    FU
  23. cg82
    cg82 Member
    yeah i read that after I couldnt get it to work. just waiting for some time to fire it up and try some more samples.
  24. FtUp
    pacific northwest
    well I am about ready to do some more powder coating. I have a bunch of parts sandblasted and ready to go. a couple have some nicks that need to be fixed first though.
    I bought this stuff to repair the nicks, hope it works...
    http://www.ebay.com/itm/231470023276?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    I also received my replacement brake master cylinder lid from 4nik8r here on the forum and got it blasted and ready to go. thanks to 4nik8r for selling me the cover. fortunately the corrosion did not cause any heavy pitting.
    before...
    after blasting and ready for powder coating...
    FU
  25. FtUp
    pacific northwest
    well I am still working on getting the parts the way I want them before I get to coating. the aluminum solder I bought was just the trick to repair the gouges. smoothing the ribs on the valve cover is proving to be a bit of work, but it is progressing.
    FU
  26. cg82
    cg82 Member
    nice. I have been PC'ing quite a few parts, both triple clamps, lower forks, bolt heads, brackets, i did the headlight and air box covers. love the stuff. one thing i learned is, DO NOT BE IMPATIENT waiting for flowout. I did on one piece and instead of gloss got a matte/textured finish. it takes time, depending on size of piece and how thick the powder is to flowout. other than that, good luck! there is something so sweet about coating a bare piece of metal and seeing a nice brand new finished piece afterwords.
  27. FtUp
    pacific northwest
    thanks for the tips.
    FU
  28. Skwerly
    Skwerly Member
    Yucaipa, CA
    This is so cool! I've been highly interested in powder for some time, too; looks like I need to hit CL for an oven and HF for a gun. :D Where do you get the custom paints?
    Hey, nice work!
    rocs82650 likes this.
  29. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Am I correct in seeing PC in the throttle shaft seal area, as well as the fuel inlet pipe opening? You will need to clean that out ASAP. Otherwise, it looks great.
  30. Bigshankhank
    Bastrop, TX
    Fwiw I have been toting around a HF powder coating kit for about six years now, never been out of the box. I could be persuaded to sell it if there is any interest...
  31. Skwerly
    Skwerly Member
    Yucaipa, CA
    ahem, maybe!
  32. FtUp
    pacific northwest
    you can find all kinds of pc on ebay for not a lot.
    FU
  33. Skwerly
    Skwerly Member
    Yucaipa, CA
    thx! I think the oven is gonna be the toughest task--they want a fortune for em.
  34. FtUp
    pacific northwest
    that is number one carb, there is no fuel passage on that side. the pc is not in the throttle shaft bore, just the seal area. it is thin and smooth, so I am not worried about it there. if any thing, it will make the seals a little tighter.
    FU
