xj700n clocks
Discussion in 'XJ Technical Chat' started by denbola, Mar 9, 2014.
  1. denbola
    denbola Member
    poole,dorset,england
    hi, clocks faces on my bike are, speedo white rev counter black is this right? as living in uk not seen another model to compare thank mike t
  2. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Both the speedo and tach faces on my 700 are white. The gauges on some Viragos are black and will work on a Maxim. Could be someone swapped out the tach.
  3. bigfitz52
    To the best of my knowledge, Yamaha didn't start using white faces on their instruments until after the '83 model year, and then only on some models; somebody has swapped with an earlier tach.
  4. denbola
    denbola Member
    thanks for reply, look like another one for the wish list
  5. xHondaHack
    Orange CT
    If you have an 85 or 86 air-cooled xj700n, the tachometer will look like one pictured in this E-bay listing I found:
    http://www.ebay.com/itm/1985-1986-1985- ... 79&vxp=mtr
    It's white, and has the correct total RPM's at 11k and a 9500 redline.
    Ones for a Maxim X are also white faced and will work on your bike, but have a 12K max RPM and a 10K redline.
    Tony
  6. randyd81
    randyd81 Member
    St Joseph Missouri
    Mine are white also
