Xs400j valve adjustment
Discussion in 'XJ Technical Chat' started by Buschkj24, Mar 9, 2014.
  1. Buschkj24
    Buschkj24 Member
    Wisconsin
    Hi all, I've read a few posts on how to do a value adjustment but I have one question... On the 400 twins the engine mount is right in the middle of the valve cover. How do I go about checking my clearances without having to drop the motor? There has to be a better way...
  2. bigfitz52
    You don't have to "drop the motor" but you do have to remove that upper mount.
  3. Buschkj24
    Buschkj24 Member
    Wisconsin
    Thanks, I took the old gal apart today to check out my valves and they are within spec... But they are fairly tight. I would imagine that in the next 5-10k miles that they would have to be adjusted back to spec.
  4. Buschkj24
    Buschkj24 Member
    Wisconsin
  5. bigfitz52
    Quite likely. That's why we need to check them every 5000 miles.
