Can I use 600 cylinders on a 550 bottom end with a 550 head?
Discussion in 'XJ Modifications' started by pjb03, Mar 6, 2014.
  1. pjb03
    pjb03 Member
    Santa Fe, New Mexico
    I have to find new cylinders to bore for my big bore kit. I figure why not get a few extra cc's out of it if possible. Any issues doing this?
  2. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Just get a FZ,FJ or YX 600 motor like I did and be done with it. The 600 cylinder sleeve may not fit the 550 case without boring the 550 case.
  3. Kickaha
    New Zealand
    What size piston are you going to?
    Why not bore the 550 Barrels to suit?
  4. pjb03
    pjb03 Member
    Not an easy find where I'm at. I already have a good Seca 550 bottom end and a ported head with Yosh cams.
    60mm
    I already have barrels that have been over bore to 60mm. They don't look the best. I would like to have stock barrels to bore for my new 60mm pistons.
    I won't take the chance. I'll find a 550 cylinder.
  5. dinoracer
    dinoracer Member
    Chattanooga, TN
    let me check, I might have a set of cylinders for you
  6. pjb03
    pjb03 Member
    I'll take them if you've got them.
    Got my new pistons yesterday. :D
  7. Kickaha
    New Zealand
    What brand are they? did you get them made?
  8. pjb03
    pjb03 Member
    They're from Wiseco. I sent them my old Wiseco piston, and they made me new ones. They use a more modern ring design since the old style rings are not available in 60mm.
  9. Thrasher
    Thrasher Member
    What was the charge and how many were you required to buy?
  10. pjb03
    pjb03 Member
    Same as we talked about. Al is a good guy to work with. They have a print now, so they could do you some in 61mm for your 600.
