Green powder mold? on carbs?
Discussion in 'XJ Technical Chat' started by skippy344, Mar 22, 2014.
  1. skippy344
    skippy344 Member
    Aggieland, TX
    Hello Dear XJ Friends,
    It has been a while since I have visited. Life has gotten in the way, in a big way...
    Anyway, haven't been taking Rosie out much, after the carb rebuild. She was tight! Ran better than new! Even with my big butt on her...
    But, as of late, fuel continued to flood the bike, oil bath, and my garage floor.
    I finally go around to cleaning the carbs, and low and behold, there is a TON of this powdery green mold, that is everywhere! There was so much in the fuel rail, that each float screen had a festive Christmas green hat!
    The bowls are so full of this crap, that you can't see the bottom.
    And all the brass jets, fuel pipes, (new ones), are all corroded and nasty. Even the new seals I installed, on the fuel pipes are jacked.
    So, what caused this?
    And, more importantly, will I be able to clean all this stuff off, or will I have to buy all new again?
    Thanks for looking.
  2. rmcrow
    rmcrow Member
    N.W. Arkansas
    Sounds like seafoam residue. Yup spray cleaner will get it.
  3. hogfiddles
    seafoam doesn't leave a residue.
    Sounds like some bad fuel and some water got in there.
  4. skippy344
    skippy344 Member
    Aggieland, TX
    I have never used Seafoam in this bike.
    I had been using "Enzyme" to combat ethanol, but never had this happen before.
    I could definitely believe the bad gas suggestion! The gas sold here, in Aggieland, is so crappy!!
    Has anybody ever tried soaking the brass bits in "Brasso?"
    If the O-rings, for the fuel pipes don't hold... Chacal will be getting another order!! LOL
  5. skippy344
    skippy344 Member
    Aggieland, TX
    I usually try to use Chevron Premium, around here...
    Seems to be the least nasty.
  6. skippy344
    skippy344 Member
    Aggieland, TX
    Here are some pics, of the bowls. I should have taken a pic of the fuel passages...
  7. k-moe
    Your fuel appears to have been infected. Though less common than with diesel, gasoline can become host to bacteria and fungi. Do a thorough soap and water cleaning, followed by carb cleaner to get the water out. Before anyone jumps on the ethanol blame wagon, this sort of thing happens to all grades and types of fuel, particularly during long-term storage.
  8. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    AggieLand, eh? I spent the better part of the 90's up there getting an education. Haven't been back since they stopped building Bonfire.
    Start with spray cleaner, if it works, it an easy solution, if it doesn't well you're not out much.
  9. skippy344
    skippy344 Member
    Aggieland, TX
    I already tried my carb cleaner, and it does not remove the green stuff.
    I am soaking the brass in B-12 chemtool, right now.
    Yeah, Hank, I was at the last bonfire, good times...
    And the carb bodies are "stained" with this green muck. So, I gotta try to find a solution to remove it from the carb body.
  10. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    One thing is for sure.... It is not from Seafoam. I use Seafom all the time to clean out my carbs. I will use Seafoam every 3rd or 4th fill just by adding 3 oz. to a full tank. I found this helpfull and this may be something you want to do in the future.
  11. hogfiddles
    Here in snowmobile land, we call it 'green disease'. LOL
    The reason we are saying it isn't because of seafoam is because someone else posted "sounds like seafoam residue", not because we mis-understood you. No worries.
    Unless, of course, some foam from the sea actually got in there..........but then the salt would cause other issues-------- LOL
    dave f
  12. k-moe
    Soap, warm water, and an unwanted toothbrush.
  13. rmcrow
    rmcrow Member
    N.W. Arkansas
    The seafoam thing was mine. I had to clean my brothers where he would add almost half a can to a tank of gas then run in into his system then let it sit till it dried. That happened several times. Listen to the experts, not me.
  14. skippy344
    skippy344 Member
    Aggieland, TX
    I had a thought, I used silicone grease, to put the new O-rings in. Could that have reacted with the gas, and cause this?
    Brasso made quick work of cleaning up the brass bits.
    That is a piece of scotch tape with one of the festive mold hats. It fell apart in the tape.
    This may end very will for Rosie!
  15. Polock
    is there any bread in your tank?
  16. skippy344
    skippy344 Member
    Aggieland, TX
    Bread? Oh, that is where I left it! Duh! LOL!
  17. ilyamer
    ilyamer New Member
    Fort Collins, CO
    Hey skippy,
    Have you tried soaking your carbs in one of those buckets of carb dip? It worked great for me, I soaked all the aluminum parts overnight and just sprayed em out with canned cleaner. I didn't have to scrape anything and they were spotless. You have to disassemble if you want to soak the carb bodies, but if you haven't replaced all the seals in there then you will probably have to do that anyway to get it tuned up right when you put it all back together.
  18. skippy344
    skippy344 Member
    Aggieland, TX
    I have not done the carb dip, yet. I have been spraying and scrubbing.
    The gallon can of B-12 Chem tool is $27.
    And yes, I tore them apart last year, and got all new "stuff" from XJ4Ever. Thanks, Chacal!! Seals, O-rings, float needles, etc, so I am good there.
    And yes, I remove everything!!
    May have to indulge in the gallon can of B-12 Chem tool.
    Do you all just dip your carb body in the gallon can, and reuse for all four bodies? How many "dippings" can I do, before the chem dip is all used up?
  19. patmac6075
    patmac6075 Active Member
    MKE
    FYI, I'm pretty sure the Berryman (B-12 Chemtool) products do not eat rubber and plastic (hence the plastic dip tray)....although I personally would still completely disassemble my carb...and I would never subject the rubber seals to a carb dip.
    Was recently at a trade show and spoke with a Berryman's rep...he was the one who clued me in...
  20. skippy344
    skippy344 Member
    Aggieland, TX
    OK, so I went out and bought a damn gallon can of Berryman's B-12 Chem Dip... $27.99 @ Oreilly's.
    Got a carb body and a float bowl soaking right now.
    We shall see what happens!
    Pictures to follow...
  21. skippy344
    skippy344 Member
    Aggieland, TX
    And Done!! Re: Green powder mold? on carbs?
    OK, went to the church of Clean!
    Carbs are clean, floats are measured and spot-on, wet set is done and they are perfect, Sync is done, air mix is done and Rosie is running fine!!
    Gonna go get some gas, and abuse her a little! LOL
    What a rush, she is to ride! And I have an '06 FJR, so that should tell you how much I am impressed with her!! :D
    Ride safe, everybody! 8)
  22. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Skippy-
    Good to hear Rosie is better now.
    I also hope that whatever curve ball life had thrown at you was hit out of the park!
    So the Berryman B-12 worked well?
    Would a gallon take on all 4 carbs?
    Any special disposal of the B-12 after it is used?
  23. skippy344
    skippy344 Member
    Aggieland, TX
    Thanks, Stumpy,
    Still battling, but we will prevail!
    Yes, the Berryman B-12 gallon of chem dip worked very well!
    Since it is a dip, I just dipped the carb body and its corresponding float bowl, into the gallon can. It came with a basket, that you can lift out.
    I did one carb at a time, and it cleaned all four, nicely. I rinsed them off with warm/hot water, in my kitchen sink, (SWMBO doesn't know about that...SHHH), then back into the garage with carb cleaner, and compressed air. Clean as can be!!
    I assume that I can just keep the chem dip, and reuse it on my next bank of carbs! I have to work on my XS11 carb bank now...
    So, until it is either all gone, or really dirty, I guess I can continue to reuse.
    It was $27.99 well spent! Rosie is happy, I am happy, and most importantly, SWMBO is happy!
  24. hogfiddles
    Use it over and over..... I've used mine for four years now and haven't opened the new can yet.....
