Wet setting floats kicking my butt
Discussion in 'XJ Technical Chat' started by jshaw1988, Mar 27, 2014.
  1. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    I did get new needles, but they were eBay specials. I'll try resetting the floats dry in that area and see what that gets me. If not, I boiled the old needles with the rest of the carbs and I will give them a shot
  2. lacucaracha
    lacucaracha Member
    Napa, CA
    Good idea to try the oldies. If they work better, then you know the issue. I'd get new ones from Len.
  3. dmlyster
    dmlyster Member
    Corvallis, Oregon
    Try Chacal for new float needle. Mine worked fine upon replacement.
  4. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    Starting to get really frustrated with this. Problem is that I don't know if the needles are the problem. I'm at the point where i am ready to send them off to someone and have them set them for me. I Get one set perfectly, then drain them all to fix another one and when I set it up again, the one that was perfect the last time pisses gas until I tap/ smack the bowl with the handle of the screwdriver I am using to open the drain screws. Seriously, it cant be this complicated. I switched the new needles out for the ones that were in the bike when I bought it. Still chasing the levels around back and forth. I also have a very hard time getting the fuel to travel down the feed line sometimes and other times it runs down like it was running down an open hose. I am so frustrated I cant think of whats going on. I am usually very mechanically inclined, but I grew up in a fuel injected world. Carbs are like Greek to me.
  5. Polock
    there's someway to adjust how far the floats can hang down when the bowls are empty. without it the floats go so far down they push the needle sideways while trying to come up.
    this sounds like what you have going on.
    i don't know the official setting but if you let the float hang all the way down then push it up with your finger there should be no binding as the float starts up
  6. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    I assume youre talking about the tab that rests on one of the poles to keep the float from going too low, right? There doesnt seem to be any binding at all through any level of travel on the float. But how could I possible know?
  7. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    Yet another day with multiple failed attempts. It seems like the levels will not be consistent from one carb to the next. Is that possible? I start them all out at 17.5 mm and they all need to be adjusted up or down and no 2 are alike. WHAT IS GOING ON?!?
  8. lacucaracha
    lacucaracha Member
    Napa, CA
    The little tangs that stop them from going too low are very important. Basically they need to be bent toward the retaining arm so that the lower resting place will allow fuel into the carbs, and not much more.
    I'm still a cheerleader for the whole bad float needles hypothesis. The K&L needles had perfect action and I had zero problems with binding or sealing when the bowls were off. As soon as everything was closed up, they got screwy.
  9. skippy344
    skippy344 Member
    Aggieland, TX
    Have you done a float test on the floats, themselves? If a float is drying out, and then, filling up with fuel, it will never shut the needle valve.
    Pour about 1 or 2 cups of GAS into a clear glass container, like your kitchen, 2 cup measuring cup! (Word of Warning, SWMBO, gets REALLY PISSED when you do that, so don't do it...)
    Dry the float out for about 30 minutes, or blow it dry with air.
    Then, set it in the gas bath, as if it were going to sit in the float bowl. You can tie some mono-filament through the pivot tunnel, and drape it over the lip of the cup.
    The floats should, well, Float! If they go completely under the gas, then they are toast, and hit up Len for new/used but good, ones!
    This will eliminate another mystery.
    Hope this helps.
  10. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    I'll try the floats today as well as trying another set of needles I have abs see if that makes a difference. If not, Idk what I'll do.
  11. bigfitz52
    It sounds to me like you're DRY-setting them and then wet-checking them.
    That won't work. The "dry" setting (the 17.5mm thing) is just to get you in the ballpark. Then you need to individually WET-adjust each one so that it brings the fluid to a proper level in that carb, as measured using the clear tube held next to the side of the carb. They most likely will all end up being slightly different, measured "dry."
  12. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    The aftermarket needles and seats seem to have fixed the problem. They are all just about even with each other and no overflowing. I want going to use the seats because the screens didn't snap on the bottom, but 3 of the 4 oe seats wouldn't hold the screens anyway. So I just put them at the bottom of the wells and reset to 17.5. All within 1 mm of perfect. Now to wrestle then back on the bike
  13. Andyam6
    Andyam6 Member
    UK, Beds
  14. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    Fitz, Yes and no. I wanted the dry setting (though I didn't know what to call it before the term was told to me) to give me a starting point. So once I had something to get me started, I could wet set them. They all needed to be set 16-16.5mm from the gasket surface.
    Andy, I had not seen that. I think I will piece together a better kit from chacal and put together the spare set I was given with the bike and swap during the winter. It was much too aggravating to put them back on the bike to do it again any time this month.
  15. bigfitz52
    But again, you just said you set them all to 17.5mm and now they're within 1mm of perfect.
    Dry setting is where you do all that goofy measuring with the carbs upside down and try to measure the float height.
    Wet setting is where you fill the bowl with fuel with a clear tube attached to the drain and read what the gas inside is actually doing. THIS is the important adjustment; where the fuel level ends up. That's why we call it "wet setting." You keep coming back to the dry measurement. It means nothing. It just gets you close enough to wet-set.
  16. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    I thought i had said that. What I meant to say was that with the starting line of 17.5, I was within 2 mm of the 3mm mark on the wet wet. So i went back, adjusted the floats 1mm (yes, I know this is dry), and rechecked with the tube and was within spec on all 4. So, yes, I was measuring dry, but only so I didn't overdo it on the adjustments (which it is stupid easy to do). I guess what I am saying is before they went back on the bike, I verified them with the tube and all were good.
    Also, side note. The bike runs now, much better then before. It still surges a little, but I think I will be able to solve this with the next rebuild (on the spare set). I took it for a good 15 minute ride to see how it did. The idle hangs a bit, but power is muuuuch better then before and idle is rock solid.
  17. bigfitz52
    If it's down to a hanging idle, then you're ready to vac sync and do some fine mixture tuning.
    (Valves are in spec, right?)
  18. jshaw1988
    jshaw1988 Member
    Tampa, Florida
    Yes, valves are in spec. (You were right on that, remember?)
