cafe project mock up
Discussion in 'Hangout Lounge' started by RATTLECANREBEL, Mar 31, 2014.
  1. RATTLECANREBEL
    RATTLECANREBEL Member
    Brandon FL.
    I've been making my seat tail using the original pan most of the foam and an old Honda rebel gas tank
    [​IMG][/url][/img][​IMG][/url][/img][​IMG][/url][/img]
  2. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    The lines are all wrong with the OEM gas tank. It takes more than a set of clubman bars and a homemade tail section to make a cafe racer.
    However, if you were intending to replace the tank, then its a step in the right direction.
  3. RATTLECANREBEL
    Brandon FL.
    I kinda like the OEM tank myself but to each his own
    I flipped the bars over can't stand them that low so now I guess the rider position would be more like that of a street tracker[​IMG][/url][/img]
  4. FtUp
    FtUp Well-Known Member
    pacific northwest
    yeah I don't care for the maxim tank as a café tank either. imho, the shape is all wrong for a café.
    CN
  5. konigralph
    konigralph New Member
    Canada, toronto
    Yeah, I hope this is just a mock upf and the tank will eventually be replaced and swapped out?
  6. SHOOTER
    SHOOTER Member
    Rawlings MD
    Yes the maxim tanks are better suited for a bobber. Actually I think they are one of the best ones out there for the bobber look. As for a cafe I would maybe try to find a seca tank or something like that. Something that has a flatter look and not that teardrop look to it. Well good luck with it.
  7. RATTLECANREBEL
    Brandon FL.
    I'm starting to agree with you guys about the tank!
    But after deciding not to use the café fairing and mocking it up again after the paint oh and flipping the bars over it still look OK as a more street tracker type style but it is what it is for now till I get more money[​IMG][/url][/img][​IMG][/url][/img]
  8. Polock
    nothing wrong with the tank, you need to lower the back of the seat/bump dowm
