Boosted the battery and now nothing. Not even clicking sound
Discussion in 'Hangout Lounge' started by shooterhead, Apr 11, 2014.
  1. shooterhead
    shooterhead New Member
    Edmonton, Canada
    What could be the problem ?
  2. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    How are the fuses?
  3. shooterhead
    Edmonton, Canada
    Re: Boosted the battery and now nothing. Not even clicking s
    Thanks. Fuses seem fine.
  4. PilotSmack
    Calgary, Canada
    Seem fine? Or are fine? I blew a fuse when I needed a jump last year.
    If the fuses are fine, the problem is likely the battery.
  5. ProjectManLee
    ProjectManLee New Member
    London UK
    Have you checked fuses for continuity and the wiring with a multimeter?
    Could maybe be a burnt out wire?
    It took me a whole day to find a broken wire that was stopping power getting to the switch.
    Project.
  6. bigfitz52
    "Boosted" it with what?
    It would also help if we knew what bike you're talking about. Put it in your sig, please.
  7. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Also just because a battery is holding 12.4V doesn't mean it has enough amperage to crank the engine. I believe the term is surface charge.
  8. RevRider
    RevRider New Member
    Grand Rapids, MI (Ionia)
    If the fuses and battery is good definitely sounds like a wiring problem. I had a similar problem last week. Thought it was my starter solenoid, since my starter button wasn't getting the job done. I cleaned the solenoid up and still wasn't working properly so I was jumping the solenoid to get the bike started. A couple days later I wasn't even hearing the clicking sound so I took apart the starter button and checking the contacts and after a little trouble shooting found that my starter bottom wasn't grounded. So I just connected a new ground and WALA... Started up with the click of a button.
  9. mlew
    Check your fuses with a meter, especially the main fuse.
  10. shooterhead
    Edmonton, Canada
    thanks everyone. I'm checking out all your suggestions now. Oh, and it's regarding a 1981 pretty much mint Seca 750!
  11. hogfiddles
    Your battery is dead. I'm 100% sure of that, too.
    Dave Fox
  12. Polock
    get a meter on the battery
    key off =? volts
    key on = ? volts
    press start = ? volts
  13. shooterhead
    Edmonton, Canada
    Thanks everyone. Still nothing. I tried to jump the solenoid and still
    Absolutely nothing. I'm going to replace the battery because it's on the low side after recharging and I'll go from there.
    81 Seca 750!
  14. RickCoMatic
    Do you have the Original Fuse Panel?
    That's where I'd look first.
  15. shooterhead
    Edmonton, Canada
    Yes. All original.
  16. RickCoMatic
  17. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    if he tried bridging the solenoid then the problem is not with the fuses,
    it must be the battery or dirty terminals,
    or a non- existant earth on engine
    or jammed starter maybe,
    stu
  18. k-moe
    Unplug the starter solenoid (the small wires) and use your battery charger as a power source. Hook up a meter to the big posts to check for continuity. when you hook up your charger to the trigger side of the solenoid (again the small wires) you'll know if that is the problem if the meter dosen't show continuity between the two big posts (even if the solenoid clicks).
    Do not discount the very real possibility of multiple faults in the starter circuits. Start at one end and slowly work to the other, one part at a time.
  19. shooterhead
    Edmonton, Canada
    Thanks, kindly! All of your advice is truly appreciated! I'll get this figured out yet!
  20. RickCoMatic
    Applying Electrical Current to troubleshoot wiring is risky business.
    I use a 9-Volt Battery.
    You can get a Test Jumper at any RadioShack .
    9-Volts --> Low Amps!
