LOOKING FOR A NEW TANK
Discussion in 'XJ Technical Chat' started by fordguy101, Apr 18, 2014.
  1. fordguy101
    fordguy101 Member
    CT
    Looking for a new tank for my xj550. Looking for other peoples input on what tanks if any will fit unmodified. There was only one real xj550 tank on ebay that I would take but for 200 bucks I figured I would get input from others who have been down this road. :?:
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    What is wrong with the old tank? Also is it a Seca or Max?
  3. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Why are you looking for different tanks other than an XJ? What style are you looking for?
  4. fordguy101
    fordguy101 Member
    CT
    The tank got dented bad in storage 4 inch dent on the top of the tank. I spent a week last year restoring and painting this tank, NOT doing that again. This spring I have spent a ton of man hours and money to get this thing tuned and running good. It now runs 100% and I would like to be at least presentable. Almost all the ebay xj tanks are in worse shape then mine is.
    Ps its a maxxim 8)
  5. Bigshankhank
    Bastrop, TX
    Is the metal around the dent creased, or just pushed in? You can seal the tank (plug the petcock and use a rubber plug for the filler) and put about 2-3 psi compressed air in it, then use a hair dryer to warm the metal and relax the dent out until it pops. A heat gun would be quicker but would flake your paint.
  6. fordguy101
    fordguy101 Member
    CT
    Well, there is a line in the middle, definetly not as bad as a crease. I feel like the line would be semi noticable after it was pulled but like I said no were near as bad as if there had been a major creas. That might just be a viable option as the tank selection(this far) is not good at all!
  7. Polock
    here's one that you can't dent
  8. fordguy101
    fordguy101 Member
    CT
    Very nice, I bet I can make one of those!
