Engine Replacement
Discussion in 'XJ Technical Chat' started by ImmPoser, Apr 20, 2014.
  1. ImmPoser
    ImmPoser Member
    Rochester NH, USA
    So... last year I had some fun. While making my way down the highway my engine failed and started smoking. I managed to nurse it over to the right side of the highway despite rush hour traffic... thankfully. I get it to the side of the road and I find a giant hole just below the exhaust on my engine.
    I had a spare parts bike so I swapped out the engine only to find out it was seized.
    So... I'd like some suggestions about my next course of action
    1) Attempt to unseize the engine. Success is doubtful considering the amount of water that came out with the oil when I emptied it.
    2) Frankenstein something together between the two engines.
    3) Buy a new engine.
    Any advice would be appreciated.
  2. hogfiddles
    Being that you have a 550, you're limited to the chain-drive engine.......
    Dave F
  3. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Tear down both engines, swap internals from good engine into the cases from the siezed one. Keep the good top end. This is what a parts bike is for.
  4. bigfitz52
    There is no "good" one.
    One is seized, the other blew up big time.
    I'd look for another motor; it would be the least expensive and probably only alternative since both motors have obvious bottom-end issues.
  5. JohnStonePhoto
    JohnStonePhoto Member
    The Woodlands, Texas
  6. JohnStonePhoto
  7. Bigshankhank
    Bastrop, TX
    Didn't read that, OP only stated that he has a hole in the engine that was most recently running. Could be from road debris, in which case it may be salvageable, or it could be a thrown rod in which case yeah, it's all-new engine time.
    First things first, establish what you know to be true; is the first engine damaged internally, or is it just the case?
  8. bigfitz52
    Highly unlikely it was road debris.
  9. Bigshankhank
    Bastrop, TX
    True, but not impossible. My nephew has an R6 that snapped its final drive chain and holed the case. Sadly, I had warned him his chain was too tight when he first showed it to me. Oh well, young and dumb as they say.
    My point being, be certain the engine is wrecked before tossing it aside.
  10. ImmPoser
    ImmPoser Member
    Rochester NH, USA
    Yeah... Very much blown out. Have a picture of it but the forum was mad that it was to big. Thrown rod sends likely. So... New engine it is.
  11. ImmPoser
    ImmPoser Member
    Rochester NH, USA
    I don't want to give up on it but it may have reached that point. Maybe I can resell all the extra stuff I put on it.
  12. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    be patient, keep your eyes open, check craigslist and ebay.
  13. mtnbikecrazy55
    yeah keep your eye out on CL and ebay
  14. Bigshankhank
    Bastrop, TX
    Or check around at local salvage yards. Good luck, sorry your engine is wrecked.
