Need opinions,,,warped,,or just rebuild
Discussion in 'XJ Technical Chat' started by jablze33, Apr 21, 2014.
  1. jablze33
    jablze33 Member
    Altoona, PA
    OK,I have an 82 xj750 seca,,an either the rotor(s) are warped or the caliper(s) are hanging up or both. There are blackish marks on the outer edge which is about 5" . What should I do?
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Original breaks?
  3. jablze33
    jablze33 Member
    Altoona, PA
    Yes, I can't upload the pic I took or u could see
  4. jablze33
    jablze33 Member
    Altoona, PA
    Sorry,guess I should've mentioned that I can here an intermittent rub as I ride.. I do think I need to overhaul the callers but I'm worried about the rotors too.
  5. Xjrider92117
    San Jose Ca
    Do you have a manual? That will show you how to check your rotor'(s). There good to have around.
    Yes I would say you need to rebuild your complete brake system.
    Brake lines
    M/c
    Calipers
    Pad
    And you need to checkout your back brake make sure it still in tacked.
    Search around this site and there's lots of info...
    Like this.
    http://xjbikes.com/Forums/viewtopic/t=15874.html
  6. jablze33
    jablze33 Member
    Altoona, PA
    ,I have a Haynes. Thanks for the input
