Fuel Tank Dents, filler
Discussion in 'Hangout Lounge' started by donho41, May 2, 2014.
  1. donho41
    donho41 New Member
    Orange Park Fl
    Can anyone recommed a good filler, I have a few small dents in the fuel tank and can't get to them the push them back out. Do I need to take it down to metal to use the filler? Or can I leave some primer? Thanks Donho
  2. 4freese
    4freese Member
    United States
    3M makes a spot putty metal filler that I get from Advance Auto Parts. It has worked for me on numerous occasions.
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Bondo. And yes, take it to the metal.
  4. Gunbunny
    Gunbunny Member
    CT
    Bondo is love, bondo is life.
    Sand it all the way down, clean with acetone for good effect, and then lay the bondo on thick. Sand, contour, finish sand, seal, prime, paint.
  5. donho41
    donho41 New Member
    Orange Park Fl
    I'll be working on it this weekend thanks for the great advise, this site is awesome, Donho
  6. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I'm sorry, did someone say Bondo?
    The red is actually Bondo Glazing and Spot Putty, applied after all the Bondo was sanded to fill the very small pinholes that develop, instead of having to sand more damned Bondo off the tank.
    It's been over a year since I did my tank, and the thought of it still hurts my sanding muscles.
    Oh, and CAUTION CAUTION CAUTION
    Make sure you drain the tank and let it COMPLETELY air out the fumes for AT LEAST 24 hours before you start sanding on that sucker. We've had more than one member lose some arm hair because of the static electricity generated during sanding igniting a spark to the tank, and that in turn igniting the fumes, which are actually the flammable part of petrol.
  7. donho41
    donho41 New Member
    Orange Park Fl
    Thanks for all the great info, I still have my arm hair and the tank is very happy now. Bondo and glazing putty worked great. Donho
    I,m thinking about Copperhead Metallic Paint for the tank, side covers, and a few other parts.
