where does this wire go?
Discussion in 'XJ Technical Chat' started by borjawil, May 4, 2014.
  1. borjawil
    borjawil New Member
    lansing mi
    I have a white and red striped wire coming from the wire loom near the battery and it has another wire connected to it from the PO. It is not connected to anything from there. Any ideas where it goes?
    1982 Seca 750
  2. schmuckaholic
    California
    Could be a battery sensor bypass to keep the computer from triggering the BATT warning. This should give you an idea of what's up:
    Battery Sensor Bypass kit
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    yep, definatley battery level sensor wire , it attaches to the middle cell on the battery,(if you have the correct battery)
    shown here in the middle of the battery
    stu
  4. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Just attach it to the positive side of the battery and the light will go out. I just had the same issue with a 1983 GS100.
  5. borjawil
    borjawil New Member
    lansing mi
    would this prevent it from starting?
  6. k-moe
    Actually don't do that if you have an XJ with the systems monitor computer. A direct connection of that lead to the battery will result in an over-voltage condition that will damage the monitoring system.
    OP:
    Click the link for the bypass kit. You can get the parts locally if you are comfortable doing the soldering work yourself. Otherwise the kit is a good buy. Once installed the battery light will come on if the battery voltage drops too low.
  7. borjawil
    borjawil New Member
    lansing mi
    You say dont directly attach it yet that is exactly what the directions for the bypass kit say.
  8. Polock
    the bypass wire is more than just a wire
  9. k-moe
    The bypass kit includes a resistor to drop the voltage down, as well as connectors so you don't have to do any soldering (if you so choose).
  10. borjawil
    borjawil New Member
    lansing mi
    Ah i see. Any idea on the resistor? I have no trouble doing the work myself
  11. k-moe
  12. borjawil
    borjawil New Member
    lansing mi
    awesome thanks!
  13. Bushy
    Bushy Active Member
    Mines straight to battery + no probs, been there about 4 years. Read it here first and others hadn't had a problem.
