left me on the side of the road
Discussion in 'Hangout Lounge' started by Krow, May 31, 2014.
  1. Krow
    Krow New Member
    Tucson, Az
    So here I sit on the side of the road. I took off from a stop light and 1/2 way through the intersection something with my throttle broke....bike runs fine but when I twist the grip nothing happens. It just flops back and forth. No springing back to closed....no throttle. Oh yea...and no tools. Got a buddy coming out to help. Wish me luck.
  2. SteelMan
    SteelMan Member
    Oregon
    Sorry for your bad luck! I feel you though man. I was leaving work yesterday on my Seca for class, just got out of the parking spot when my bike started to act funny, then my clutch handle went limp and my bike died. :/ Hopefully its just the cable like mine.
  3. hogfiddles
    Either you cable snapped, or it popped out of the bracket on the carb rack. Check to see if it just popped out of place first.....
  4. redsix
    redsix Member
    Western Pennsylvania
    Update us!
  5. TIMEtoRIDE
    ( a day late )
    If you're close to home, and the roads are safe enough, you crank the idle up and ride home.
    If you're clever, and the cable will reach, you swap the "choke" over and use that as your throttle (very carefully)
  6. Krow
    Krow New Member
    Tucson, Az
    The throttle cable snapped right at the handle. I was about 50 miles from home. A friend came by and we loaded it up in his truck and went to all 4 of the bike shops in town and nobody had a cable. I went to ace and rigged it up so I could get it home. Got the part online and fixed it up right.
    Now I washed it and all I'm getting is a click from the starter solenoid? Could it just need to dry out or am I buying parts again. Grrr. And I'm stuck at work for my 24 hour shift.
  7. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Jump the terminals on the solenoid with a screwdriver. WATCH FOR SPARKS.
    If it cranks, you need a new solenoid.
    No cranking means starter rebuild.
  8. Krow
    Krow New Member
    Tucson, Az
    I bumped the end of the starter and off she went. I put the battery on the charger just to be safe. Looks like its time to rebuild the starter. Thanks again for the advise folks.
  9. maz43
    maz43 Member
    Detroit area
    Glad you got it going.
    Unlike bike shops, Chacal stocks everything we need.
    Reminds me of a similar situation but with the clutch cable snapping.
    Luckily,I had a good tool kit on board.
    Used needle nose pliers as a "clutch lever" and got home.
    Maz
  10. hogfiddles
    You're not the first one. I know another list member who had a cable break on his way home from the LVCC. He used a pair of vise grips from PA to CT.
  11. k-moe
    Cheap insurance: ZIp tie spare cables next to the current ones. Make sure they are lubed, and seal the ends with either heat-shrink tubing, or friction tape, so dirt does not contaminate your ready-to-go-spare-cables.
