need a visual for fuel idle adjuster 85 maxim 700
Discussion in 'XJ Technical Chat' started by bohemian, May 31, 2014.
  1. bohemian
    bohemian New Member
    Campbell river
    My bike just started idling high ( in the 2000 - 2500 rpm bouncing even slightly higher) after longer periods of riding. ( over 20 min highway speeds ) at least . Just happened after I came back from a 1000km ride. I am a newbee but really want to learn to do as much as I can myself. I have a manual but the pic isn't very clear. I saw a post somewhere that mentioned to adjust the idle speed after if has warmed up substantially. I just would like a clear pic of where the screw is.
    85 Yamaha maxim 700
    thanks!
  2. xHondaHack
    Orange CT
    Here's an old post that has a couple of pictures:
    http://xjbikes.com/Forums/viewtopic/t=3 ... tment.html
    After getting the engine warmed up, set the idle at around 1100 RPMs.
    You should also make sure the throttle cable is lubed properly and the throttle snaps back to idle when released. And, make sure you have the proper play in the throttle when it's in the idle position.
    If you're still having trouble after that, you may have to start checking for a vacuum leak.
    Tony
  3. bohemian
    bohemian New Member
    Campbell river
    Thanks for the good tips Tony! going to have a go at it today:)
    should I just use wd40 on throttle cable?
  4. xHondaHack
    Orange CT
    You'll definitely want to get some cable lube.
    WD40 is not appropriate for that type of application.
  5. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    thank you for this thread and the link
    my xj has always had to have the choke on a bit for it to run
    and yes I know they are pretty much the same thing
    being able to turn my choke off cause the idle is set
    right is so nice
