Electrical Question (Turn Sigs)
Discussion in 'XJ Technical Chat' started by SecaSaver, Jun 1, 2014.
  1. SecaSaver
    SecaSaver Member
    Canada
    I'm replacing the stock turn sigs on my Seca. The new ones have 10w bulbs, versus the stockers 23w bulbs. When I wired one in on the front to test it today, that side would only stay lit solid, instead of flashing.
    When I balance the circuit by installing another 10w stalk on the rear, will the flasher work, or am I shagged using stalks with 10w bulbs?
    Thanks in advance.
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    The stock relay needs two bulbs a side to work properly, so 46 watts per side total.
    The only way the 10w bulbs will work is replacing the flasher. Bussman 552 works great for the Secas.
  3. SecaSaver
    SecaSaver Member
    Canada
    Thanks...
    Called a buddy who's an auto mechanic, and he said pretty much the same thing as you..."You'll need a new flasher to run the low wattage bulbs, just like when guys switch to LED turn sigs."
    Is it possible to buy 23w bulbs in the same smaller socket size as the ten watters, I wonder?
  4. SecaSaver
    SecaSaver Member
    Canada
    One more question...
    I assume the flasher is the small metal cube, just behind the tool tray, under the seat?
  5. bigfitz52
    No, that one's the sidestand relay.
    And if you swap out the flasher unit, you'll lose the self-cancelling feature unless you do some "engineering" to restore the functionality. (The original flasher unit is designed to work hand-in-hand with the cancelling unit.)
  6. SecaSaver
    SecaSaver Member
    Canada
    I picked up a Bussman 552 today, BTW.
    Not worried about the self-cancelling, but thanks for the heads up.
    So where the heck is the flasher relay, anyhow? In the headlight? :oops:
  7. CapnRedbeard
    CapnRedbeard Member
    London England
    have a look under the tank , just In front of the coils.
    Three pronged rely unit..:)
  8. tskaz
    tskaz Active Member
  9. SecaSaver
    SecaSaver Member
    Canada
    Good stuff...Thanks, guys.
    Oh and...Since the 552 is a two-prong unit, is there only one way it can go into the three prong plug?
  10. bigfitz52
    Len has round relay holders too, with the same "mounting configuration."
  11. SecaSaver
    SecaSaver Member
    Canada
    Is there only one way the two prong 552 can go into the three prong plug?
  12. FtUp
    FtUp Well-Known Member
    pacific northwest
    yes, it's polarity sensitive. here is a schematic that uses a single pole double throw relay to maintain the self canceling feature.
    http://xjbikes.com/Forums/viewtopic/t=1 ... rt=30.html
    CN
  13. SecaSaver
    SecaSaver Member
    Canada
    Thanks again, guys...
    New turn siggies installed, and Bussman 552 flasher plugged in and working properly...
