CDI Compatibility - 86 XJ900
Discussion in 'XJ Technical Chat' started by discostu_001, Mar 12, 2013.
  1. discostu_001
    discostu_001 New Member
    Anyone know if the CDI unit of an xj750 is compatible with the xj900??
    The model number i have is CDI (TID 14-37 58L-10)
    Cheers, Stu
  2. 750E-II_29Rbloke
    South Cheshire, UK
    None of our XJ's have a CDI, it's a TCI :p
    Not only me being pedantic, but will help you in searches etc to use the right term. The 750 one will likely allow your bike to run but the timing will be a way out & will lose you a ton of power & possibly cause overheating, so not a good idea I'm afraid.
    If you put your incorrect one up for swaps there's a chance somebody will have what you're looking for though
  3. adrian1
    adrian1 Active Member
  4. discostu_001
    Thanks; and yep after some more research I now know the difference between tci & cdi.
    I'll have to source another xj900 tci unit from a similar year.
  5. 750E-II_29Rbloke
    South Cheshire, UK
    Hang on, tired so just noticed that you have a 58L TCI? That is a 900 TCI...
    What model bike do you have?
  6. discostu_001
    Yep I have an 86 xj 900, I've sent off my tci unit to get repaired. Hope to get it back this week!
    I was searching for alternatives as the tci units second hand are hard to get a hold of.
  7. 750E-II_29Rbloke
    South Cheshire, UK
    Right I get ya :) Do you know what was wrong with it or what caused the failure?
  8. discostu_001
    So I sent off my TCI unit to an auto elect (Jack @ City Auto Electrics in Coburg, VIC) who diagnosed that one side wasn't firing.
    Not sure if it was a broken solder or if it just needed a cleanup. But $290 later, I have a working TCI unit with a warranty...
    Plugged it into my bike and it fired up like normal on all four.
    Thats an expensive win, but a win all the same :)
  9. 750E-II_29Rbloke
    South Cheshire, UK
    Expensive yes, that's why I was wondering if you knew what caused the failure in case it happened again. Didn't they tell you what they did? I'd wanna know they'd removed, tested & polished n resoldered every part for that money :D
    Glad she's running good :)
  10. adrian1
    Did you not think second hand was an option on this one? or.....?
  11. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Ya gotta do what ya gotta do, but yikes!
    Tell ya what... I'll take care of ya next time for the low, low, price of $250. :wink:
  12. baz666
    baz666 Member
    Washington, DC
    tough one. i tried that but the 900 has it's own timing set up not related to 750s etc. Prof. John Oughton owns my old XJ900 and i think he had this issue. Look him up.
  13. darkfibre
    darkfibre Member
    Perth, Australia
    $290? Holy cow!
    Most TCI units just need the electrolytic capacitors replaced and a full resolder of every connection. On occasion you may need to replace a coil driver (transistor).
    Anyone got any dead units? It may be worth me repairing some and offering an exchange service, as I have repaired ECUs etc as a job for many years and can actually bench run these units.
    A previous play;
    TCI repair
  14. discostu_001
    I thought about buying one of the Hyperpack units from NZ but wasn't sure about it... http://bit.ly/106xD06
    I couldn't find a second hand one and didn't want to spend weeks looking.
    Anyway, carbs balanced & tune done, running perfectly with my pipes :) Pretty stoked > Pic attached
  15. quebecois59
    Very nice bike! What are these mufflers exactly?
  16. discostu_001
    They're a pair off a Triumph Thruxton. Thank you ebay.
  17. quebecois59
    Do these mufflers sound as good as they look?
  18. discostu_001
    Ah they could sound better; pretty quiet to be honest. However they do look great.
  19. discostu_001
    14 months later, same problem :( FML and the repaired TCI unit is out of warranty
    Cylinders 2 & 4 not firing...
    Started after riding home in the wet, there seems to be no water getting in under the seat though... what else might be causing my TCI unit to fail?
  20. k-moe
    What's the output from your voltage regulator look like?
  21. discostu_001
    Thanks for the reply, turns out it was a faulty plug! replaced and back to normal.
  22. adrian1
    Lol. Yet another "check the simple stuff first" story! Glad you got it sorted!
