Rear diff
Discussion in 'XJ Technical Chat' started by voyager, Jun 6, 2014.
  1. voyager
    voyager New Member
    Worcestershire UK
    Hi all, does anyone know if you can get a higher geared Differential for the Maxim X700 Water cooled model.
    Or are they all the same through the XJrange of shaft drive models.
    It's just that my bike seem to be working hard and not going very fast.
    Mike.
  2. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    If you have a water cooled 700, it should run like its arse was on fire and its head was catchin'. Are your valve clearances in spec? Are the carbs clean and floats set properly? There is no reason to change the gearing.
  3. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    As far as I know, the gearing is what it is. It's a high revving motor that runs like a scalded cat. You just have to get used to running it hard.
  4. voyager
    voyager New Member
    Worcestershire UK
    Thanks for the info, it's probably the fact that I don't like revving it.
  5. bmarzka
    XJs hit their power band at about 5000 rpm. If you are shifting at 3000-3500 rpm or lower, it will be a dog. This ain't your daddy's V-twin. Rev it up, play it loud, have some fun. These motors sound so awesome at 9 grand, it is a REAL rush.
  6. Brothastonebones
    Brothastonebones New Member
    Pacific Northwest
    Yeah just in town riding I typically shift above 5k and cruise above 4
  7. k-moe
    You have in your XJ what is essentially the same engine as was put in this wee beasty.
    You are riding a sportscruiser. Rev that motor.
  8. Brothastonebones
    Pacific Northwest
    That thing is gorgeous
  9. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I'm not sure why you guys refer to the final drive as a "diff". Technically speaking a "diff" has 6 gears inside the case where as I hope you all know that there are only 2 gears inside shaft driven motorcycles. The only exception I know of is a German army BMW with a side car; it did have a "diff". Anyway FYI. Call what it you like, it makes no diff to me.
  10. k-moe
    The majority of us don't. We call it the final drive, which is what it is. A lot of people who are unfamilliar with shaft driven motorcycles will refer to it as a differential out of familiarity with the term, and because it resembles the differential thhat would be found on a car.
