Loud shift.
Discussion in 'XJ Technical Chat' started by blackdiscoball, Jun 17, 2007.
  1. blackdiscoball
    blackdiscoball Member
    dayton, Ohio
    Hi, nOOb here. I just bought an 1982 XJ650. This is my first street bike and I had a quick question for you smart folks. I did I search and didnt find anything so I hope this isnt one of those questions that gets asked alot but my bike seems to shift kind of loud. It doesnt have problems shifting and it doesnt grid it just makes a loud pop/click noise. I was just wondering if these bikes just shifted loud and it was normal or not?
  2. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    In all the gears? Or just a clunk into first and a bit notchy from 1st to 2nd?
    Does it clunk going down?
    Clutch adjusted right?
    Try a oil and filter change.
    Using the clutch to upshift?
  3. RickCoMatic
    What kind of oil do you have in there?
    And do you have enough?
    Put some 20W/50 in it and see if it gets any better!
  4. LincsTriker
    LincsTriker Member
    Lincoln, UK
    Hi black
    I've got a 1982 XJ650 engine in my trike and that has a loud clunk going into first, I've not had any problems with it.
    Hope this helps
    Lea
  5. blackdiscoball
    dayton, Ohio
    It does seem to happen most in first to second. I did just change the oil and filter with some Penziol 20W50 synthetic. Kiwi what do you mean by clutch adjusted?
  6. KiwiXJ750D
    KiwiXJ750D Member
    New Zealand
    This thread has a guide to adjusting your clutch correctly:
    XJBike thread
    It's just to be sure that your clutch is set right.
    Alot of XJs seem to be a bit notchy from first to second and neutral to first "clunk"! If you have new oil and it's not too bad or hard to engage or jumps out of gear (esp. second) don't worry, just keep the oil n filter changes regular. She'll go for years.
  7. blackdiscoball
    dayton, Ohio
    Thanks! It didnt sound to bad so I guess its just normal. Ill adjust my clutch just to be sure.
  8. whisperer
    whisperer New Member
    Central Oregon
    My 5K mile Maxim X is a little notchy going from N to first and about half that much going from first to second. I'm thinking they are just that way from right out of the box. Make sure your clutch adjustment is correct.
    I changed my oil from dino to Redline 20W-50 4 stroke Motorcycle oil and it did help some with the notchyness. Yeah it's expensive, but hey, it's only 3 quarts.
  9. Old-Grunt
    Old-Grunt Member
    I suspect the driveshaft has something to do with the notchy shifting not as much give in drivline to let things rotate into place as a chain,I know to tight of a chain on a chaindrive bike can affect shifting,I realy dont know but it makes sence to me
  10. RickCoMatic
    Fine-tune your Clutch adjustment.
    Use the Knurl on the Clutch Lever Perch.
    Loosen the Locking thumb wheel.
    Turn the adjuster until there NO play in the Lever.
    (Yea, yea ... I know the book says a couple of mm's ... don't sweat it)
    When you have all the freeplay out ... you'll kiss the clunk, redlight creep and hard finding Neutral problem ... good-bye!
