81 550 maxim cutch wont disengage
Discussion in 'XJ Technical Chat' started by Newmax-x, Jun 30, 2014.
  1. Newmax-x
    Newmax-x New Member
    Picked up a 81 550 as a fixer upper last fall. The last problem I've encountered is that after sitting over night the clutch wont dis engage unless I bump start in gear. pull clutch in crack the throttle a couple times and it will release and seems fine after. Do you think this will resolve with use or could something else be wrong. The bike was stored for several years,
  2. Newmax-x
    Newmax-x New Member
    no thoughts on this?
  3. bigfitz52
    You have changed the oil, right?
    What oil did you put in it?
    The clutch will probably need to be rebuilt, they generally do.
  4. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Put the bike in first gear, pull the clutch, rock the bike back and forth.
    Has the bike been sitting for a while? If so, the clutch's friction plates may have 'stuck' to the steels. I had this happen when I was working on mine after a 10 year storage period.
    If that doesn't work, it may be time to pull the clutch apart and replace the friction plates. Sometimes, if they are not evenly oiled for long periods of time, the friction material can swell on one side and not on the other (submersed) side.
  5. bigfitz52
    The friction pads that weren't submerged in oil while the bike sat dry out and become petrified little rectangles of linoleum.
  6. Newmax-x
    Newmax-x New Member
    Thanks for the info. may have to pull the clutch, But ill do another oil change first to see what happens.
