Hello All
Discussion in 'Hangout Lounge' started by hrubak, Jul 9, 2014.
  1. hrubak
    hrubak New Member
    NE, Ohio
    I just picked this XJ 550 Maxim. Lots of useful info from you guys, Thanks. Runs, but needs brakes, lines, tires. I rebuilt the master cylinder. ordered new SS lines and pads, shoes.
    EDIT: Added better pics below
  2. biggs500
    biggs500 Active Member
    Sherwood WI
    Looks real nice. Good find. It looks like your on the right track as far as maintenance stuff goes. Let me be the first to say this: "check the valve clearance".
    Here's an excellent walkthrough. Remember to disconect the battery first.
    Welcome to the forum. :)
  3. biggs500
    Sherwood WI
    Nice dog too. :D
  4. hrubak
    hrubak New Member
    NE, Ohio
  5. biggs500
    Sherwood WI
    Good pictures. Just an FYI, I noticed you have the side stand down while it's on the center stand. Be sure to put the side stand up before you roll it off the center stand. If it lands on you foot :x you'll say some choice things rather loudly.
  6. hrubak
    hrubak New Member
    NE, Ohio
    Thanks Biggs. The PO had the valve shims done a couple years ago and put 100 miles on it since. I will check them since im going to refurbish the valve cover anyways. it only has 15,000miles on it and has been under cover in a climate controlled basement :) im pretty sure every rubber piece needs replaced due to being 32 years old, but i plan on restoring this to showroom new.
    I had the side stand down due to cleaning.. its hard to get to the chrome collector with it up.
  7. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Welcome. Are you close to Erie?
  8. peganit2
    peganit2 Member
    Davison Mi
    Welcome and that is a sweet, sweet bike you have. 8)
  9. peganit2
    peganit2 Member
    Davison Mi
    Welcome, and that is a sweet, sweet bike you have. 8)
  10. hrubak
    hrubak New Member
    NE, Ohio
    I am in portage county.
  11. hrubak
    hrubak New Member
    NE, Ohio
    Thank You! It runs good, but i still need to get the maintenance done before i can stretch its legs.
