Clutch issues or my fabbed carb spring?
Discussion in 'XJ Technical Chat' started by 83midnightmaxim, Jul 15, 2014.
  1. 83midnightmaxim
    83midnightmaxim Member
    West Virginia
    Hey guys last time i was on here i was asking about my weird clutch issues after my bike rebuild where it would only rev to high rpms and go a little then when the rpms dropped it would almost stall without some fancy clutch playing. I have been super busy at work and havent had much time to tinker with it but remembered that on my rebuild i had misplaced my diaphram spring for one of the carbs and had to fab up a new one that was bent somewhat but being eager to ride the bike thought it might work? Could this be the real issue or should i stop thinking about easier solutions and just worry about the clutch? Funny thing is though i dont remember even messing with any adjustments on the clutch to make it act like this the only weird thing at all i did mechanical wise on my build was fab up one of the carb diaprham springs from an old scooter. What do you all think? Thanks
  2. k-moe
    Not having the correct siaphram spring(s) can indeed cause you a world of trouble. That may be the cause of your situation, and it is certianly less of a bother to correct then changing the clutch plates would be.
  3. 83midnightmaxim
    West Virginia
    Thanks k moe its the same problem i had last time i was on the forums regarding the clutch problem. i ordered a new one as i lost the old one im eager to try this fix i hope it does work i never thought it would create an issue like this but i guess i was wrong.
