love them carbs
Discussion in 'Hangout Lounge' started by Fongdingo, Jul 26, 2014.
  1. Fongdingo
    Fongdingo Member
    Charlottesville VA
    Mine are about to be cleaned. There so dirty I'm not really sure how the bike ever started. Vales are being checked on Sunday.
  2. mwhite74
    mwhite74 Member
    The good news about 4 carbs is you have 4 times the practice. The bad news about carbs is you have 4 times the practice. Looks like you know the drill.
    Are you going to break the rack and tackle that puzzle as well?
  3. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    I would suggest on breaking the rack and replace the throttle shaft seals as well as the fuel rail seals. It also makes it less cumbersome to handle one carb at a time when cleaning and polishing. My experience was 3 months after a cleaning without breaking down the rack, the fuel rail seals began to leak.
    I will never do a cleaning without breaking the rack from now on. Do it right the first time and be done with it.
    Hope this helps
  4. bigfitz52
    Even more importantly, if you don't plan to break the rack yet, DO NOT submerge or even "flood" the still-assembled carbs with cleaner. If you manage to drive cleaner into the throttle shaft seals, you will be breaking the rack.
  5. Fongdingo
    Fongdingo Member
    Charlottesville VA
    Was not planing on breaking them apart. I did that on my first bike and it was not fun,and I was told after that it really was not needed.
  6. bigfitz52
    It may or may not be.
    The best practice is to CAREFULLY "service" the carbs, and then see where you're at. A lot of people overdo it and end up damaging what might have been perfectly good throttle shaft seals.
    The problem is, there is no way to be sure without examining them. Or fighting with mysterious tuning issues after having done everything else. You can get a clue (but only a clue) by carefully examining the only two you can easily get to, the outer two (on carbs #1 and #4.) If those two are shot, then chances are the others are too. However, if those two are in decent shape, it's no guarantee for the other six that you can't see.
    It's a crapshoot. Sometimes the seals are in fine shape; sometimes they're "decent ~ok" and sometimes they're a collection of disconnected little rubber rings floating on the shaft no longer sealing anything. Sometimes there's almost nothing left but a halo of rubber.
  7. hogfiddles
    Your about 10 minutes away from breaking them the rest of they way down. Do it now, or you're gonna be about two hours away from them when you find out they're leaking.......
  8. biggs500
    biggs500 Active Member
    Sherwood WI
    +1 on Hogfiddles last comment.
  9. Fongdingo
    Fongdingo Member
    Charlottesville VA
    So I should break them all apart? Even if the bike started up with out instant start and started but ran at a 5 k rpm.
  10. biggs500
    Sherwood WI
    Yes. Replace the seals and the fuel rail o-rings. You'll be glad you did.
  11. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    I am in the midst of the same process, and all of my fuel rail o-rings and shaft seals are brittle. It's quite simple to break the rack, just do it and know that it was done properly.
  12. Fongdingo
    Fongdingo Member
    Charlottesville VA
    OK I will be breaking them tonight. I just remember the last time I did this some parts went flying
  13. adrian1
    adrian1 Active Member
  14. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Break that rack.......do it right the first time or learn the hard way.....it will cost you more money but will be well worth it in the end......trust everyone's advice to break that rack.......you are there anyway......do the whole 9 yards.....
  15. Fongdingo
    Fongdingo Member
    Charlottesville VA
    All broke down. Into the dip they go,then a boil then dip then a wash . that should clean them up
