putting turbo on 81 xj650
Discussion in 'XJ Modifications' started by hohenstein23, Jun 23, 2014.
  1. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    I have an 81 xj 650 and i know they made a 82 xj650 with a turbo.
    I found on ebay the 82 turbo carbs and the manifolds. I was wondering will the carbs work for mine 81 and will the manifold bolt up. My brother is a proffesional fabrication so we can do some modding. Do you think this will work
  2. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Would the carbs even work with the 81
  3. k-moe
    In all honesty you'd be better off doing a clean-sheet system using a modern turbo. There are internal differences between the turbo and non-turbo engines that preclude just bolting the factory system onto a non-turbo bike. They factory turbo system really wasn't all the good anyway. It added weight and complexity without enough extra go.
  4. hohenstein23
    hohenstein23 Member
    Clyde Ohio
  5. hohenstein23
    hohenstein23 Member
    Clyde Ohio
    Thanks i will just keep things the same
  6. vesparider
    vesparider Member
    douglass ks
    81 Maxim Turbo Using 83 seca Turbo Driveline. Almost a bolt in. 16psi and a real hoot to ride.
  7. dirtymike
    dirtymike Member
    that looks like one hell of s ride to me. Will she do a ton in a 1/4 mile. Dirty
