fried ground to battery from main switch area
Discussion in 'XJ Technical Chat' started by feetballhabob, Sep 14, 2014.
  1. feetballhabob
    feetballhabob Member
    Kentucky
    the ground wire coming to the battery from the area of the main switch got hot , and shorted out on my 85 xj 700 water cooled.the insulation melted of off near the battery.any ideas what happened. the bike was running when this happened
  2. Polock
    how sure are you that it's a ground wire that's burnt
  3. feetballhabob
    Kentucky
    the wire goes back to negative side of battery not really sure
  4. k-moe
    Which XJ is this?
  5. feetballhabob
    Kentucky
    85 xj700 water head
  6. Polock
    a - wire can't burn unless it gets + form somewhere with no load between them.
    even then it should have popped a fuse long before a wire burnt.
    any hacked wiring on there ?
    you found the battery end, see if you can find the other end where the smoke started, that should be the problem end
  7. feetballhabob
    Kentucky
    thanks will let you know where it ends up
