How hot do you think our engines get?
Discussion in 'XJ Technical Chat' started by Gulrok, Sep 20, 2014.
  1. Gulrok
    Gulrok Member
    Washington
    I'm looking at using a hall sensor for an ignition project.
    The sensor says it can be used from -40C to 125C ( 257F)
    If anyone has one of those thermal heat guns that give you a temp reading. Would you unscrew the left-side cover and shine it on the ignition pick-up sensor and tell me how hot it is.
    I tried finding numbers but I wasn't able to.
  2. bostonbacon
    bostonbacon Member
    Boston
    Haynes manual doesn't have that info, just checked. A few of the guys here have the full shop manuals and may be able to see if there are any kind of spec there. Which bike do you have?
  3. Polock
    i have a temp sensor on the valve cover right on the cam tunnel part. it holds the max reading and right now it says 275f, after a few years of riding. so that's right over the heads, setting in traffic on hot summer days. i think down on the ignition you'll be ok
  4. Gulrok
    Gulrok Member
    Washington
    I think you're right. I let the bike run for about 10 minutes to run. Then I pulled off the ignition side.
    It was warm, but I was able to touch the pick-up sensor and pieces without burning my hand.
    Thanks for the general reading though. 275F at the heads isn't bad when the sensor can handle 257F and is at a lower and cooler part of the engine.
  5. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Be careful. Our bike's engines cool and re-charge as we ride. Ten minutes is a bit of time for it not under load. Keep a fan(s) blowing on the engine and try not to drain the battery. Hope this help.
    Gary H.
  6. Polock
    if you think you might run the battery down, just unplug the headlight.
    rocs82650 likes this.
