Help with diagnosis
Discussion in 'XJ Technical Chat' started by sybe, Sep 4, 2014.
  1. sybe
    sybe Active Member
    NYC - Brooklyn
    I have a 82 xj650 maxim that I recently pulled the carbs to do a partial rebuild to fix sluggish acceleration. Everything went great floats were wet set to spec, everything was cleaned and bench synced.
    While vacuum syncing the carbs i started to run into an issue. The bike would hang when I revved the motor and it would sometimes slowly drop.
    Today...I inserted a yics eliminator tool to try and re calibrate and i got the idle and carb to a good place. The main problem I am having now is when i took it for a test run the bike would spike a high rev when stopping. I debated a vacuum leak and notice a boot between the air box and carb not sitting right. I still need to colortune the carbs, I am just not sure if the issue i am having is a vacuum or fuel mixture issue.
    any help is appreciated! this is my first bike so its hard for me to trouble shoot.
  2. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Vac sync needs to be done with the bike warm. Take it for a good 10+ min ride, then put a fan toward the engine and do the sync. Adjust your idle so it stays around 1200, then do the sync and adjust idle as necessary. Remember to oil the seals on the eliminator to avoid them melting in your YICS port.
    Definitely fix that boot. I always just use a small flathead screwdriver for that.
    Colortuning comes last. After all other quirks are figured out.
  3. sybe
    sybe Active Member
    NYC - Brooklyn
    Here is an image showing how ther boots are fitting, you can see some of them aren't sitting right.
    When i did the cab sync the bike was warmed up, i'll see if i can post a video tomorrow of the carbs sync level.
    Would these issues cause the bike to rev high when I come to a stop?
  4. hogfiddles
    Yes
  5. irritateddave
    irritateddave Member
    Virginia
    Mine was doing that after my tune. Turned out that my throttle cable was sticking and not letting the butterfly valves to snap shut.
  6. Polock
    on those boots, Take a look at the area under the clamp, you should find a oval mark in the rubber. That goes on top. Some times the clamp gets in the way, I only clamp 1&4 , 2&3 get no clamp or a long zip tie.
  7. TIMEtoRIDE
    The airbox-to-carb boots are not the cause of a hanging idle,
    the integrity of the intake boots, gaskets, rubber caps, petcock hose, and throttle-shaft seals are in question.
    Check for vacuum leak.
    Test with an unlit propane torch, can of ether/starting fluid,
    or if you're bold, flow a garden hose over your suspected leaky item.
  8. hogfiddles
    But it CAN be a source.... Have had it happen. I've also had it be the source of the oroblem for another bike that wouldn't start.....
  9. mwhite74
    mwhite74 Member
    When it's revving high, gently press down on the sync screw (gently) and see if the idle drops. This will let you know if either butterfly is binding, which only really presents the symptom when it's warm. each butterfly needs to *tink* when each of their actions are released, if you follow me.
    I've had a similar problem, which is something to not overlook either. if that proves to be the issue you'll likely need to split the rack and reset each butterfly.
  10. sybe
    sybe Active Member
    NYC - Brooklyn
    I got the carbs synced up nice and level and while i was doing it the bike would start to rev high to 3k rpm. to lower it i would adjust the idle screw and it would come back down to 1500 rpm. i havent rode the bike yet to test it but i suspect it will still spike revs.
    I was using a DYI auxiliary tank so i am not sure it is the petcock since it would still spike the revs. The one symptom i did have prior and part of why i pulled the carbs off is that i was getting fuel into my oil. so it might possibly be the petcock.
    how do you test the throttle shaft seals?
  11. bigfitz52
    Fuel in the oil is a float/float level issue. The petcock supplies fuel; the floats are responsible for shutting off fuel at the right level. Gas in the oil is NOT a "petcock issue" it indicates a float problem of some sort.
  12. sybe
    sybe Active Member
    NYC - Brooklyn
    Ok cool, then that should have been fixed when i reset the float and swapped out the needles for the all metal ones(not in that order). i read somewhere that gas leaking into the oil could be from a leaky petcock. Glad to know now that isn't the issue. Saved me from buying a new petcock.
  13. bigfitz52
    I didn't say it isn't an issue. It isn't the CAUSE of the issue; it can enable a poorly sealing float valve to not do its job.
    If your floats are working correctly a leaky petcock can't contribute to the gas in the oil issue. If the floats are working correctly you could (in theory) leave it on PRI and nothing bad would happen.
  14. andrewc
    andrewc Member
    guelph ontario canada
    Revs can hang on a little if the pilots are out of adjustment.
    You asked about checking the V-seals. Use a torch and the revs will spike if they are leaking vacuum.
  15. sybe
    sybe Active Member
    NYC - Brooklyn
    I did the propane trick and it didnt increase the revs. so i am happy about that. However when i started the bike today there was a popping sound coming out of the motor as if the gas wasnt igniting properly. some sort of back pressure/blowback. this is making me think the fuel mixture screws are open too wide.
    I made this video of the motor running and the bike idling high. Hearing the way the motor runs in the video I am starting to get concerned there might be an issue with the motor. One of the odd things about the high rev is that it will do it out of no where and i am not sure at this point what else to look for.
    I didn't have this problem before i pulled the carbs.
    [video=400,180]http://player.vimeo.com/video/105828728[/video]
  16. sybe
    sybe Active Member
    NYC - Brooklyn
    So i am still having the issues and i am about to pull the carbs again. Today i noticed the shaft connection that the fuel line connects to spins like it is loose. is that supposed to move? it rotates up and down and would that cause the issue?
  17. Rsk_141
    Rsk_141 Member
    Scotland
    I Feel your Pain.
    I'm having trouble with Carbs on my 1980 Seca
    With the Bike Running i Pulled the Vacuum Blanking Plugs off one at a time
    There was no change on 2 Cylinders, No2 and No4, Obviously an Air Leak,
    I found that there was an Air Leak in the Butterfly Shafts,
    What i did was, Wearing a rubber work glove, Marigold gloves will do
    I Pressed my finger over the Shaft of No4 Cylinder
    And the Revs Started to Rise,
    You Could give it a Go, See If It Works for You.
    Hope this Helps
  18. sybe
    sybe Active Member
    NYC - Brooklyn
    Been busy with work but this weekend i got a lot done. I put on a new MC... what a difference. Now the front tire actually stops tight! new clutch cable, throttle cable and pulled the carbs to check the valve and redo the bench sync. Everything looks spot on. I decided to check the airbox and i noticed a screw was missed on the left side. Once i put a new screw on and pushed the box forward it is now allowing the boots to sit flush. Not sure how that screw vanished but its fixed now. previous owner i guess...
    Tomorrow i plan on re-vacuum syncing the carbs and color tune them. Originally i have 2.5 turns on the mixture screws i lowered it down to one full turn just to see if that helps.
    When i pulled the bowls off today to see if the jets were ok the sizes are as follows 112 and 42. Looks like the previous owner made them larger. I wonder if he added a jet kit.
  19. sybe
    sybe Active Member
    NYC - Brooklyn
    I will definitely try this tomorrow. Just to make sure you put your finger over the C clips and the revs rose up?
  20. bigfitz52
    Your valve clearances are in spec, correct? If not, then trying to vacuum sync is a waste of time.
  21. sybe
    sybe Active Member
    NYC - Brooklyn
    No idea, that is something i plan on tackling in the winter when i garage it at my parents house. Right now all the work is done on the street and i was too concerned with something falling into the motor. call me paranoid but i dont want to risk it.
    However i got great news. I got the bike fixed. Carbs vacuum sync (all level), color tuned, and no more high revs.
    The one thing the bike is still doing and i am not sure why is a slight hesitant coming out of first gear. I put a new clutch cable on and i will be adjusting it during the week using this as a guide
  22. Polock
    there's a perfect example of why you shouldn't believe everything you see on youtube
  23. k-moe
    Park the bike until you check your valve clearances. They have probably never been checked and a burnt valve is in your future if any of the exhaust valves are out of spec.
  24. sybe
    sybe Active Member
    NYC - Brooklyn
    In an ideal world i would be able to do the valve shims next week but its hard to do them when you live in Brooklyn and use the street as your garage.
  25. hogfiddles
    So then just to make sure that you totally understand-----once you do your valve shim clearance check and most likely change some of them, you will need to do the syncing and colortuning all over again. But hey....look on the bright side---now you have the experience of doing it already.
    Dave Fox
    MBFTY likes this.
  26. MBFTY
    MBFTY Member
    Lumberton, NJ
    I use the street as my garage, and I still manage. Plastic bags and packing tape to cover over open and exposed components. So far I have had my carbs out twice, both wheels off of the bike for extended periods (not at the same time), and even retapped and installed an insert into a sparkplug hole. That was a fun project that required 3 extension cords to get the shop-vac out to the bike to suck the metal that ended up in the cylinder.
    My 3 year old neighbor came out to question what was going on.
    "Mr. MBFTY, what are you doing?"
    "I'm vacuuming my motorcycle, Jaylon."
    "How come you have to vacuum your motorcycle?"
    Kids are great. So are properly adjusted valves. Check them, garage or not.
  27. hogfiddles
    Yeah, sometimes kids have to have the clearance in their heads adjusted too......
    MBFTY likes this.
  28. sybe
    sybe Active Member
    NYC - Brooklyn
    I've done that plenty... Carbs 3 times, rear brakes, front brakes, rebuilt caliper, new MC, and 2 oil changes. I want to give my neighbors a slight break, I have been working on the bike for the past 3 weeks on and off o_O. Anyway what are the symptoms of needing to replace the shims and what would cause hesitation out of first gear? bad clutch plates?
    I am using castoil 20/50. would that cause the issue with the clutch plates?
  29. MBFTY
    MBFTY Member
    Lumberton, NJ
    How many miles on the motor?
    My first suspect is improperly adjusted clutch cable. My second suspect is worn internal trans parts.
    Symptoms of needing to adjust valves include, but arent limited to, poor performance, valvetrain noise, hard starting or not wanting to idle, or even not idling without choke. If you do not have previous service records to show the valves were serviced, assume they werent. This is one thing that like EVERY fairweather motorcyclist doesnt do. Its somewhat expensive and they wont worry about it. Just change the oil and go. The 80's was an era of tons of fairweather motorcyclists. If you dont have records, then it wasnt done.
    In my camp, we only use motorcycle specific oils. Ill go and tell it from the highest peaks that you should only do so as well. Others will argue otherwise. Your own personal mileage may vary. I will say the oil has something to do with the shifting issue. But, as I said... your personal mileage may vary.
  30. sybe
    sybe Active Member
    NYC - Brooklyn
    bike has 12k+ miles. No idea what was done and wasn't. The oil i use is motorcycle oil see image below. I hope it is the clutch. Sometimes when shifting from second to first it wont engage and grinds a bit or it wont engage first gear and slides into neutral.
  31. bigfitz52
    You're using the correct oil. Your clutch could probably stand adjusting; and/or the cable needs to be lubed or maybe even replaced.
    At 12K if your valve clearances have been ignored, you're approaching the "danger zone" for a burnt valve. The initial check was to have been done at 3K with subsequent checks every 5K thereafter. The valve clearances tighten, not loosen, and if ignored you will eventually burn a valve. Simply CHECKING them can easily be done no matter where you're working on the bike. We've got a weeks' worth of nice weather coming; don't keep riding the bike and putting it off.
