Running Really Bad
Discussion in 'XJ Technical Chat' started by Rsk_141, Sep 14, 2014.
  1. Rsk_141
    Rsk_141 Member
    Scotland
    Hi Just been Trying to My XJ650 to run better, at the moment Starts fine idles no Problem, take it out it quite sluggish till about 3000 Rpm, then pulls like a train, does not go much above 5000 rpm, and after about 10 - 15 mins it gets all popping and dies and difficult to idle and start.
    Any Suggestions are Welcome,
    Many Thanks
    Gary
  2. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    start with a compression test.
    Make sure all the valve clearances are in spec.
    Church of clean and rebuild of carbs
    bench sync,
    wet set floats to spec
    new spark plugs
    make sure battery is good and charged
    in line fuel filter
    Petco*k working as designed
    running vacuum sync
    colortune air fuel mixture.
    There are write ups on all topics. There are no short cuts to getting the bike to run correctly.
  3. bigfitz52
    Valves first; it sounds like the classic symptoms of a motor in need of a valve adjustment (if it's not too late.)
  4. Rsk_141
    Rsk_141 Member
    Scotland
    got to the bottom of the problem Today..!, Yippee!
    Well i hope so,
    Already Done the Shim Thing
    Carbs Cleaned
    Bench Balanced
    Float Heights Done
    Inner Tubed the Intakes
    New Plugs
    Only when i started to Colour Tune, it wouldn't adjust Orange Flame
    we had a Air Leak in the System,
    This is when we started to find the issue,
    Replaced the Vacuum Blanking Plugs, started it up and pulled them off individually, No2 and No4, No Change, tightened up jubilee clips on the Intakes, Nothing, Placed my Rubber gloved finger over the End of the Butterfly on No$ Shaft, Revs Started To Rise,
    So I Think That There Must be An Air Leak on the Shaft.
    Any Suggestions on how to fix will be much appreciated
    Gary.
  5. bigfitz52
    That would be throttle shaft seals.
    The rack has to be broken down, and each carb will need to have its individual butterfly and shaft removed so that the seals on the shafts can be replaced.
    There are (2) seals per carb, eight in all. The only two that can be easily accessed are the very outermost two, on the outsides of carbs #1 and #4.
  6. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    get the throttle shaft seals from Chacal......& tear the carb rack apart to replace, if you do it right the first time, you will only be doing it once.....be patient, be methodical......follow the instructions.....
    http://www.xj4ever.com/hitachi%20thrott ... 0seals.pdf
    rocs82650 likes this.
  7. Rsk_141
    Rsk_141 Member
    Scotland
    Cheers for the Advise Guys, Parts Ordered from Chacal, He's a Good Guy, Really Helpful.
    Will have to get on with some other tasks while i wait for the Parts,
    Fingers crossed this will be it Fixed and Ready to Go!, and i can go out enjoy the bike, the weather is starting to turn a bit Winterey so i hope i can, get a few days before it gets too Bad, But we might get better Weather in the New Independent Scotland Who Knows?
  8. fiveofakind
    San Diego, CA
    You might as well change the fuel o-rings while you have the rack apart....see chacal for the fuel o-rings as well.......now is the time to do it when you are replacing the throttle shaft o-rings....
    Just a suggestion....
  9. Rsk_141
    Rsk_141 Member
    Scotland
    Totally, I Get what your Saying,
    But I Think I'll Burn that Bridge When I Come To It.
    LOL!
  10. BruceB
    The bridge is already on fire....just saying..
    I tore my carbs down, did the church of clean, replaced and put back on bike.
    Wouldn't idle...
    Tore down replaced throttle shaft seals, Len suggested fuel rail o-rings...I ignored suggestion..
    3 months later, fuel rails were leaking badly.
    Again, carbs off the bike and tore apart.
    30+ year old rubber o-rings need to be replaced sooner than later....
  11. Rsk_141
    Rsk_141 Member
    Scotland
    Got everything back together, color-tuned and balanced Carbs,
    Went out for a test and got More Issues!
    Going along Fine Gets to 3000 rpm jumps up to 4000 rpm, Throttle will not shut Down constant 2000 rpm,
    get it back in the drive and Revs Hanging / Increasing at Idle
    Please Help?
    Shims Done
    Float Heights Done
    Inner-Tubed Inlets
    Throttle Shaft Seals Done
    Carbs Stripped and Cleaned
  12. hogfiddles
    Adjust your idle speed screw.... The big knurled on that sticks out between the center two bowls---- turn it counter clockwise to drop the rpms. If it all the way out already, then your butterflies are not closing correctly. Could be upside down, or a spring binding, or bench sync not done quite right first.....
    But check the idle speed screw first---
  13. Rsk_141
    Rsk_141 Member
    Scotland
    Not Idle Screw, wish it was, Took great Care With Butterfly's (see Pics)
    will have to strip carbs again.
  14. Rooster53
    North, FL
    Is the idle screw all the way out and still revs high?
    Was the idle normal during the first carb balance (sync)?
    Normally, balancing should not be done until the bike is fully warmed, like a 10 mile ride. Then put a fan on the motor and re-balance / colortune the carbs.
    Did you take great care in installing the butterfly's (throttle plate)? The clearance holes in the throttle plate are quite a bit larger than the screws to allow for tolerances to enable the throttle plate to center in the carburetor bore in order to completely close.
    To install the throttle plate, hold the throttle plate against the flat portion of the throttle shaft while the throttle plate is fully closed in the carburetor bore, then secure the screws.
  15. Rsk_141
    Rsk_141 Member
    Scotland
    Went Through Everything Again, Stripped Cleaned Bench Sync Etc.
    Tick-over to 3000 Rpm everything's fine
    Gets to 3000 Rpm then it wants to rip your arms off, Mini Power-Band thinks it's an RD350LC
    Gets to 4000 / 5000 Rpm Rev Jump up and it like the clutch is dragging,
    Clears up above 5000 Rpm but does not pull Clean,
    Checked the Needle for Wear no real sign, checked Jet Size 110
    Any suggestions Most Welcome
    Gary
  16. k-moe
    Did you pull the emulsion tubes out to check the metering holes?
  17. Rooster53
    North, FL
    Re-read some of your earlier posts where a PO was very creative in grinding valve shims, and you had valve clearances way out of spec (too loose). So given that there could be some more PO related issues.
    K-moe's question is good, hopefully you pulled and cleaned the emulsion tubes during the cleaning.
    Is the hanging idle still present?
    The jets say 110, but are they really? The PO could have done some drilling?
    Did you check to see if the needle jet that extends into the main jet was not shimmed by the PO? They are not adjustable as in clips to move the needle up and down, but shim washers can be added to move the needle up to go to a richer mixture.
    Since the gallery is no longer present, and I could not find any photo of your bike: does it have the stock exhaust and air filter box - no pods?
    How about electrical - new plugs, a quick ohm check of the coil secondary resistance to verify plug caps are OK?
  18. Rsk_141
    Rsk_141 Member
    Scotland
    Emulation Tubes Pulled and Cleaned,
    Needles No Shims,
    Motad 4-1 Exhaust,
    New Plug Caps 5k Resistor, Cut Back Leads
    New Plugs Not R,
    This is an Unknown for Sure, But Throwing $90.00 For New Jets May Not Fix It.
    Motad 4 into 1
    Stock Air Box
  19. Rooster53
    North, FL
    Yea, I would not want to throw $90 away either and would attempt to diagnose the issue more before doing that.
    How many miles on the bike?
    Did you happen to do a compression test after adjusting the valves?
    What about the hanging idle, is that still a problem?
    By not pulling clean, is it missing?
    Does it backfire / pop in deceleration?
    Does it have the stock air filter also and is the lid present?
    Link to information overload hour for lots of informative reading. In reference to main jet sizes it recommends going up +4 for the 4-into-1 exhaust, however, it also states that typically no jet changes are required for aftermarket exhaust changes... so I am a bit confused on that one.
    http://www.xjbikes.com/forums/index.php?threads/the-information-overload-hour.27544/
  20. quebecois59
    ARe these carbs equipped with the two extra air jets on both sides of their "mouth" (airbox side) alos called compensation jets? There are not of the same size and they are often mixed up due to a mistake in the service manual, maybe that's your case?
    THey can be seen on this picture:
  21. Rooster53
    North, FL
    I thought this was the mistake in the Haynes manual:
    A - larger hole is the pilot air jet, they have "A" labeled as main air jet
    B- smaller hole is the main air jet - they have "B" labeled as pilot air jet
    The POSITIONS of these two Jets, in the photograph appearing on pg. 123, are CORRECT.
    3 Holes - Right side looking down and in.
    LABELING of the 2 Jets is NOT Correct.
    Also thought you would never make it through color tune if these two were swapped?
  22. Josh1026
    Josh1026 New Member
    Missoula, MT
    Have you checked the intake manifold gaskets? I had a similar problem with a hanging idle, i made some gaskets for it and that problem went away. Now it won't idle but that is a different story. Have you tried the propane or starter fluid test around your manifolds?
  23. Ted
    Ted Member
    Sioux Falls, SD
  24. Rsk_141
    Rsk_141 Member
    Scotland
    Sorted was Running Lean
    No Just, Really Sluggish
    Yeah a Little Bit
    Yes
    I got +4 for 4-1 Exhaust = 4
    Add up all the main fuel jet size increases and subtract 2 sizes. =2
    - 2 for stock Air Box + 4-1 exhaust =0
    Yeah That's Been Checked Too!
    Thanks for all you help but i my thoughts on this are:
    The Weather is on the Turn not many days before it becomes to wet to go out and have Fun
    So Just Going to Ride it, it not the best but In A Couple of Days I Won't Even Notice, "Over Come and Adapt"
    And Deal With This Next Summer.
    That's Some Good Prices even With Int. Shipping And Tax.
    Thanks again.
    will Keep you posted about any developments
