82 maxim 650 hardtail
Discussion in 'XJ Modifications' started by dozer75840, Sep 4, 2014.
  1. dozer75840
    dozer75840 Member
    buffalo , texas
  2. dozer75840
    dozer75840 Member
    buffalo , texas
  3. dozer75840
    dozer75840 Member
    buffalo , texas
    So after I got her stripped I got my grinder out and went after a few rust spots(just surface rust nothing rusted out) the blue paint is just to protect the bare metal until I get the fab work done
  4. dozer75840
    dozer75840 Member
    buffalo , texas
  5. dozer75840
    dozer75840 Member
    buffalo , texas
    I also made my first cut tonight if you can't tell in the picture. I just laid the piece up there for before and after deal
  6. dozer75840
    dozer75840 Member
    buffalo , texas
    So here is what the frame looks like now with the seat are cut out.
    I am using the brothers who are p2fabrication on this site build to get some ideas from on how to go about this. I figure whit what I have in the bike I'm not losing much if I screw up this early in the game
  7. dozer75840
    dozer75840 Member
    buffalo , texas
  8. dozer75840
    dozer75840 Member
    buffalo , texas
    We'll this is where I am now hopefully I can get some time to work on it next week!! Can't wait to hear all of y'all's input! I'm open for any and all suggestions at this point. I'm going to keep reading and find out some more stuff on the hardtail and see what is out there
  9. dozer75840
    dozer75840 Member
    buffalo , texas
    Alright so I got the bike mocked up how I think I want it to sit. I'm going Friday morning when I get off to get the tubing to start get the pieces tacked up before final weld. I will post pictures soon of the frame mocked up. I also started into the motor tear down. Number 1 rings are smoked!! But I'm going to need some help on doing at least a partial rebuild on this engine. Anyone out there know of any literature on the engine other than the repair manual or is that all I should need?? Oh and thank you guys for all yall advice and help
  10. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Not salt throwing but did you compression test the engine to determine its status (you said #1 rings are toast)? The manual(s) are a good source for info and are very necessary. Use that/them and ask questions here...you should be fine. I haven't split the case but I've rebuild the top end. My best advice...attention to detail. Triple check your work and make certain everything is going back together correctly and don't work beyond "too tired"...get sleep and look at it with fresh eyes. Remember...the only stupid question is the one not asked when the correct answer is here. Last thing you'll need is to button it up get ready to fire it then wonder if you missed anything. Good luck with the build.
    Gary H.
  11. dozer75840
    dozer75840 Member
    buffalo , texas
    Yes that was the first thing I checked. That's what lead me to a rebuild. Number One was only showing 75 psi of compression the others were over 100
  12. dozer75840
    dozer75840 Member
    buffalo , texas
    So I know it's been awhile Since I posted an update but I have been pretty busy with work. I finally got time this weekend to work on the bike and we got one side finished and welded in. I'll post pictures.
  13. dozer75840
    dozer75840 Member
    buffalo , texas
    This is what I used to get my height for the build
  14. dozer75840
    dozer75840 Member
    buffalo , texas
  15. dozer75840
    dozer75840 Member
    buffalo , texas
  16. dozer75840
    dozer75840 Member
    buffalo , texas
  17. dozer75840
    dozer75840 Member
    buffalo , texas
    I still have to do the other side. I have a pretty good idea on how to do it but any opinion would be greatly appreciated
