Ideas to hide electronics on xj650 hardtail
Discussion in 'XJ Modifications' started by XJoe, Nov 6, 2014.
  1. XJoe
    XJoe Member
    Sioux Falls, SD
    Ok.. I have see a few ideas for hiding the electronics by the battery... but I need more directly from you guys... help ideas please!!
  2. Orange-n-Black
    Memphis Area
    I would mock up the rear first, put the battery in and see how much space is left. That will be a big determination about the electronics box.
    One of the members here made a octagon shaped box and put the regulator on the end to vent. That's another consideration heat build up, you'll want to vent but not let water in.
  3. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Find a Harley oil tank with battery holder. Gut the tank and relocate electronics into tank.
    Orange-n-Black likes this.
  4. Polock
    there's a cave behind the steering neck in the frame
  5. hogfiddles
    Th coils take up some of that area though....
  6. engraverwilliam
    engraverwilliam Member
    Baldwin Hills, South Los Angeles
    I saw someplace someone mounted an old tin first aid kit right under the seat
  7. Josh phillips
    Josh phillips Member
    Bettendorf, Ia
    thats a neat idea, I love unique. This will be a project I must tackle down the road as wel.
  8. Skwerly
    Skwerly Member
    Yucaipa, CA
    Thinner ammo boxes are also an idea. I have a few of those, will probably utilize one of 'em on my build. :)
  9. k-moe
    Just be sure that the voltage regulator gets plenty of air moving over it. Pushing a bike home sucks.
