easy carb removal
Discussion in 'XJ Technical Chat' started by mainexj550, Jun 27, 2007.
  1. mainexj550
    mainexj550 Member
    maine
    Hey, Ive removed my carbs a couple times now and it is a PITA. The problem is getting those boots between the air box and carbs off and especially back on. The process usually requires about 15 curse words and it makes my hands cramp up.
    Is there some secret technique I am missing? Maybe its not a secret at all.
    thanks
    ***Watch the language please, Robert***
  2. rgouette
    rgouette Member
    Maine,USA
    Well, I know there folks here that swear by the "push the boots into the airbox" method, but I found them sticking out too far & it made the job harder I thought..
    I dunno, maybe I missed a step..
    I end up just sorta, tearing them out of the airbox entirely, & a little WD 40 makes them slide in again easily.
    I am assuming there's no damage done because of the WD40, but who knows maybe over time..
    I've gotten to where I can now go from start to carb rack in hand in about 5 minutes, I've done it so many times now..
    Sad , but true!
    Cheers!
    Rich
  3. mr_ex
    mr_ex Member
    maine usa
    if youre boots are old and "HARD".....pushing them back into the airbox is the only way to go.....otherwise yu will tear em all to dog snot.
    its also easyer to hook the carbs to the airbox boots first upon install.....atleast it has been for mee :wink:
    as alwayse with carbs....repeated install and remove....will give improved results as yu learn the little tweaks.
  4. mainexj550
    mainexj550 Member
    maine
    Thanks for the replies. Ya, my boots are still pretty soft and pliable. The last time I did this I pushed the two center boots though the air box. PITA.
    I'm going to try some of these other methods this weekend.
    Thanks.
  5. mhhpartner
    mhhpartner Member
    Louisiana, USA
    Maine:
    Not sure if it works on the larger bikes, but on my 400 removing the airbox screws/bolts (2 on top, 1 on right side behind battery, 2 on left side) allows the airbox to drop back and down a slight amount, which makes the task easier.
    My boots are still pliable, and after removing those airbox bolts the carbs can then be pulled/pushed across the boots without damage.
    Herb
  6. Polock
    make yourself this little tool to help the boots along when your fingers are too short or hurt to bad
    .156 steel wire, no sharp edges, welding rod
  7. Danilo
    Danilo Member
    Vancouver canada
    IF.. your frame allows simply undo the upper rear subframe bolts so it and the airbox can rotate backwards about 6" to 8", which makes carb instal VV easy.
  8. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Which bike is this on? I assume you have a Maxim X?
  9. chilidog
    chilidog Member
    tampa, FLA!!!....365days of riding/year
    having done 3x times on the xj700n im thinking the only improvements might be better curse words colder beer and having the bandaids ready....
  10. Piersol
    Piersol Member
    Red Lake Falls, MN U.S.A.
    Pics? Or a sketch?
  11. samsr
    samsr Member
    Colorado Springs
    I have found on my 700 that if you take off the mounting screw or bolt on the top of the air box. You know, the one that mounts it. And slide it back, that it make the job much easier. If the air box boots are nice and plyable then just push the carbs back in then onto the intake boots. Push hard then they go right in. A little wd 40 helps the carbs go right on. Good luck. Practice make it go much faster also.
