petcock issues, please help!
Discussion in 'XJ Technical Chat' started by tom.mcmullen, Nov 6, 2014.
  1. tom.mcmullen
    tom.mcmullen New Member
    Yelm washington
    Rebuilt the petcock just now with oem factory parts (1981 seca 750 xj) the selector/switch to move from on to res to pri doesn't move now. I took it back apart to compare and same stuff just newer and in better condition lol. Any thoughts. I know it has something to do with the o-ring on it.
  2. hogfiddles
    Tom, often a symptom of inadvertently putting the indexing plate in upside down, or backwards.
    Take it back apart and check. If you STILL have trouble, PM me and I'll take one of mine apart for you to compare.
    Dave Fox
  3. tom.mcmullen
    Yelm washington
    Thanks, sometime today or tomorrow I'll take mine apart and take pics.
  4. hogfiddles
    Let us know what you do or don't find
  5. tom.mcmullen
    Yelm washington
    Not sure what was wrong with it. Took the o-ring out then back in and now it works. Maybe it wasn't seated right or something
  6. hogfiddles
    Good.... Problem solved!! :)
  7. tom.mcmullen
    Yelm washington
    Yup, now cam cover seal, spark plugs, fuel and it should fire up
