1981 XJ650 Alaskan Bobber Project
Discussion in 'XJ Modifications' started by Roguesaint, Nov 1, 2012.
  1. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    I had the other thread started for some advice, wasn't planing on putting up the progress photos there so i'm starting a new thread to post progress photos as i go along. Here's a before:
    Started Teardown:
    Almost completely stripped and ready for motor R&I and hardtail chop:
    Removed front fender mounts and smoothed out:
    Welded holes on the neck and removed stock tank mounts:
    Motors out and ready to start choppin:
    I work at a bodyshop, came in over the weekend and made up a 3 stage color for the tins; a gold metallic and kandy green for the top coat:
    Welded/patched the EFI hole on a sportster tank i picked up for cheap. installed the new bung for the petcock that will eventually fit between the double frame section of the backbone:
    So here we are as of 12:30 last night; cut the rear section, fabed the rest of the hardtail pieces and tacked them in place. I have to give some major love to Crath for the photos of his hardtail job, going to be using that post for quite a few ideas. The designs he had in his bike looks great and thank him alot for the inspiration. So its all in place, welding is fairly new to me so a buddy of mine who used to weld for a living is going to come by to final weld all the joints that i have tacked down ( don't need the ass end falling out on me going down the highway) :
    Still need to do the cross joints for the seat mounts front and rear, weldup the spacers that go down on the lower swing arm where they attach to the frame like Crath did for the extra support, couple of rear fender mounts, battery tray and do a few gussets here and there and this thing should be ready to black out.
    Thanks for looking, more to come soon!
    Bendigo XJ guy likes this.
  2. Ted
    Ted Member
    Sioux Falls, SD
    Oh, man this is sweet.. great work so far, keep 'em comin'!!
  3. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    Thanks man! Its hard work but i'm having a blast learning and working my way through this project.
  4. tuba6869
    tuba6869 Member
    are you using the front fender for the rear?
  5. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    No I was going to originally but I was able to find a trailer fender at local truck and trailer shop that was perfect. A guy at a custom bike shop up here recommended me to go check it out. Paid $25 for it, thick steel and the shape curves perfectly to my rear tire.
  6. MiGhost
    MiGhost Well-Known Member
    Just a minor suggestion. Replace the stud in the final drive with a bolt. It will make removal of the final drive assembly much easier when necessary.
    Ghost
  7. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Roguesaint,
    Nice build so far.
    Gary
  8. tuba6869
    tuba6869 Member
    that fender looks good though and for 25 bucks cant beat that!
  9. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    Yeah the fender was definitely a good find.
    Thanks rocs82650.
    So I finally got my buddy to come by and weld that stuff up.....and then i ran out of f***ing wire in the welder.....at 9 pm on a saturday night, when no hardware store is possibly open. Oh well it is what it is, we had plenty of beer so i guess the night wasn't a total wash ;)
    We finished the piece that mounts to the final drive. Going to smooth it out and mud the welds once everyting is said and done. Took a few close up shots of the mounting bracket.
    I'm probably going to leave the back how it is, want as much material on it as possible, the front will eventually be smoothed out and mud the welds to make it look a little nicer.
    So with the right side at least completely welded she holds on her own
    The kick stand is still at its stock length, sits a little to straight up and down. I plan on shortening the stand and probably going to move it far enough forward that it doesn't stick out past the frame and look funny. I pulled the original exhaust brackets and removed the rear brake lever. Eventually going to b installing the tcbros forward control kit. The roadside stand is extremely handy as a temporary bike stand but it will also go away once it is no longer needed. will most liklybe he last thing to go when i am ready to paint the frame.
  10. PacNorWestHD
    PacNorWestHD Member
    Woodland Washington
    Looking good so far!
  11. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    So my buddy and i finished welding the frame pieces after a few murphy's law moments. He finally showed up to weld the last pieces of the back bone and the welder ran out of wire...at 9:00 pm when no hardware store was open. So two days ago he came by with wire and a new tip/cone and tried again, no more than ten minutes later the weldshield gas ran out. luckily a buddy had a tank sitting in his garage since the stores were closed that could fill a tank. Nothing much has changed on it short of the welds being complete so i fugured i didn't need a photo. I'm going to use Crath's idea and find some metal to weld up the gaps in between the pivot points on the swing arm and place the new crossmembers in once the new seat and the solo shock come in, will get some photos up once thats done.
  12. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    Seat is on the way and solo shock is in. waiting for the seat to start fabing up the cross members.
  13. mtnbikecrazy55
  14. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    there's nothing to really show past the last photo. will throw some up once the seat/shock come in a some progress is made.
  15. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    The bike is looking good, but one thing I noticed on the drive shaft....how far is it from the "stock" position?
    This may not be the best description, but, if the stock position was say 12 o'clock and 3 o'clock and the new position is now 12 o'clock and 2 o'clock you could get accelerated wear on the drive components.
    See the difference between the shaft on the top picture and the bottom picture. I've seen this issue mentioned before about the angle of the drive shaft.
    Just a thought.
  16. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    From what i've read on prior threads they shaved off part of the outside of the driveshaft housing to alleviate this issue. i know where it sits now is with in the area of travel that the stock suspension allowed so i'm hoping it won't be an issue, if not at least the u-joints aren't that expensive ;)
  17. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    So its been about 10F for the past month and haven't done much besides work and play video games. I finally got some time to do a little more on the bike. The seat and the shock are in and started on the brackets to do the cross members; didn't get to far on those though. Mainly focused on the sleeve support pieces borrowed from Crath's build. I removed the support section that was immediately behind the motor, still need to modify and reweld the rear brake switch back on the swing arm.
    Here is a close up of (the ones borrowed from Craths thread) the new supports between the swing arm and the outside section of the frame. Welds aren't very pretty but it'll do the trick.
    bought some spacer tubing to throw under the rear fender to start mounting it in place. cut a piece out of the fender to accommodate the drive shaft section of the swing arm.
    In the process of making the mounting tabs for the solo shock and the solo seat to mount off of the cross members. after the first one i'm seriously thinking about paying someone to do the rest with a CNC machine, that sucked...
    So here are a few photos of tonights progress. Ill be getting some more work and photos up here soon.
  18. mook1al
    mook1al Member
    Talladega, AL
    Rogue, just curious...What do you need a solo shock for? Unless you are going to change it, you have hard tailed your frame, and the shock will be nothing more than cosmetic.
  19. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    Alaskan roads arn't exactly the smoothest. i've ridden a hard tail with one of these shocks on the seat and it rides pretty nice. has the look you get from the hardtail lines, the semi-suspension of the spring seat, but the shock is a way nicer ride without the risk of bottoming out like with the springs. heres an example:
  20. rd337
    rd337 Member
    Just grab one off of a full suspension mountain bike or something. Small and the older ones would be very reasonably priced. Lots of options as far as rebound and spring weight goes! I'd recommend mounting them in an angle to get a progressive effect. I've got a Specialized Bighit and the way they designed the progressive system works amazingly well compaired to my kona stinky delux.
  21. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    Funny you mention that, the first shock i stole off my old mountain bike that never gets ridden. as i was looking at where it sits on the frame and the load of the shock it self, i didn't think it was going to work. The one off of the bike was 6 in long my new one that is meant for choppers is only three, the other had a load rating of 700lbs and the shorter one is 300lbs; making for a much smoother ride since i only weigh about 190. Besides the new shock was only 28.00 off of ebay.
  22. smokeater
    smokeater Member
    Man I am diggin this hardtail mod. What type of welder did you use?
  23. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    Thanks for the comment, there are quite a few threads doing this hardtail mod. i'm borrowing a couple from a friend of mine. the first one was a cheap one from the hardware store, not sure the brand name but it was doing the trick. Another friend of mine wasn't using his Hobart so i'm using that now. plugs into the 110 wall socket, works pretty good for what i'm doing. I had a welder buddy come and do the frame pieces since i'm still learning to weld, i'm doing the mounting tabs and some of the support pieces.
  24. rd337
    rd337 Member
    Yea I was thinking if you had ordered some 300 springs for a 6inch shock then it'd work amazingly. I've got 450lb on my bike, specialized bighit, with the progressive design. but it's had it's days and getting a little too weak now so probably getting another 450 or 500. But one thing i'd totally do if I didn't have progressive system is find a shop that builds custom springs or order something like a 150lb spring off of another setup, cut 3 inches off the heavier spring, build an adaptor to line up the springs in place so you'd have 3 inches of say 400lb and 3 inches of 150lb, and then build a sleeve to protect it.
    That would be a lot of work, but totally wicked!
    OORRRRRR
    look up pictures of the specialized bighit and how they angle the shock system to make it have a progressive effect.
    and modify your bike's mounting points!
  25. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    Thats a good point on the progresssive design. i've seen instead of mounting the shock with it compressing straight up and down, mounting the bottom of the shock farther up the frame having it angle forward slightly on the bottom, thought that would account for the progressive effect giving it some shock swivel before it starts to compress.
  26. smokeater
    smokeater Member
    Looks great.....I know you asked about the shaft angle...no bites on that one huh? I'm going to do some solid rear struts and I was wondering how low you could go without compromising the shaft angle.
  27. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    i haven't put the motor back in since i lowered it to where i did. i'll be putting up some photos of the shaft/ujoint angle when i do fo reference on other builds. i dropped the underside of the frame stand ( the roadside stand i guess its called) on to a 4x4 for my height. everything clears and the shaft should still be fine. i took that from another build and they didn't seem to have any issues down the road other than shaving the outer side of the shaft head where thy bolt together. like i said i'll have to cross that bridge when i get there.
  28. smokeater
    smokeater Member
    sounds like a plan man. Ill likley be using bolt on solid rears until I get brave enought to pull the trigger like you did and weld it up. Ill be looking for those pics of the shaft angle.
  29. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    not a problem. smokeater here is a link to the first page of Crath's build. this is where im taking a lot of my pointers. page through here and check out what he did. about half way down you'll see a pic of the flange/ujoint where he had to trim it. i'm hoping this is all i will have to deal with down the road.
    http://xjbikes.com/Forums/viewtopic/t=9 ... art=0.html
    This guys build has been alot of help for when i'm stuck on something.
  30. smokeater
    smokeater Member
    Ya I have been all over that thread.....pretty impressive build. Im seeing you guys build these bikes that push the limits of whats "acceptable" and then I also get a little foggy on wether or not the "purists" have good arguements as to why not to hardtail it or weld your swingarm or use bolt on rears....lada da dada
  31. Roguesaint
    Roguesaint Member
    Anchorage, Alaska
    lol yeah i hear ya. personally before any kind of a mod to these bikes whether cafe or the swing arm hard tail you're seeing around these threads, the stock xj bike may be one of the ugliest things i have ever seen, but with anything, has potential to be something really cool ( well...anything besides our current president ;) If the hard tail is what you want go for it, if you'd rather restore it to a really nice factory bike then that's your prerogative.
  32. aktoddc
    aktoddc Member
    Kenai, Alaska
    Hello All,
    I'm bringing this build thread back to life……I recently took over this project from Rogue. I'll be making a few changes to suit my taste. I didn't really like the Sportster tank fitment, so I went with this beauty instead-
    The tank is from Cole Foster and required converting to a single backbone, which was done in this thread-
    http://www.xjbikes.com/forums/index.php?threads/single-backbone-conversion.47865/
    And now looks like this-
    Next up will be fitting the tank, I'm waiting on the new drag bars to show up before final lockdown of the tank. Also, I have a rear to front wheel conversion kit coming.
    -Todd
  33. Orange-n-Black
    Memphis Area
    Like that tank, will be watching this one.
  34. aktoddc
    aktoddc Member
    Kenai, Alaska
    Just for fun, I set a DT250 tank up on the backbone. I'm really digging the look! Doesn't really go with the bobber theme, but would look great for a cafe racer. Good news, is that I think it would take very little mods for it to fit the stock triple tube backbone.
  35. aktoddc
    aktoddc Member
    Kenai, Alaska
    Here are the new tabs I had to make for mounting the tank.
  36. aktoddc
    aktoddc Member
    Kenai, Alaska
    And here is the tank mounted. Next up will be the seat…just waiting on brackets and airbag from TC Bros.
  37. k-moe
    That is a pretty tank.
    peganit2 likes this.
  38. Orange-n-Black
    Memphis Area
    I'm really liking that tank. The solo seat is going to look better with that tank than the original. The exposed large mount tab on the back of the original tank just kills the looks IMO.
  39. aktoddc
    aktoddc Member
    Kenai, Alaska
    Got the solo seat mounted up. It took me a lot longer than I wanted it to due to the air bag setup. I had to disassemble the seat pan and relocated the mounting studs. I mounted the seat as low and far back as possible and still have clearance for the fender. In retrospect, I probably should have just run springs or a shock/spring setup. The air bag is more of a novelty than a need, but definitely has that cool factor.
    The seat definitely goes well with the tank.
  40. Orange-n-Black
    Memphis Area
    looks great.
  41. rocs82650
    Middle Tennessee
    +1. Good lines, craftsmanship and originality. You've got this.
    Gary H.
  42. aktoddc
    aktoddc Member
    Kenai, Alaska
    Fender mounted….may cut the top back a bit…..any thoughts?
  43. peganit2
    peganit2 Member
    Davison Mi
    It is.
    Almost as pretty as the stocker's.:rolleyes:
  44. peganit2
    peganit2 Member
    Davison Mi
    True, that mount CANNOT be left exposed.
  45. peganit2
    peganit2 Member
    Davison Mi
    This is a nice looking bobber build.
  46. peganit2
    peganit2 Member
    Davison Mi
    Very nice welds.:cool:
  47. Orange-n-Black
    Memphis Area
    I like the rear fender length you have. How are you going to support the back of the fender?
  48. aktoddc
    aktoddc Member
    Kenai, Alaska
    I'm not…..it doesn't flex with the current mounting. I like the clean look without struts.
    -Todd
  49. rocs82650
    Middle Tennessee
    With the current fender length you don't have to deal with road grim being tossed onto your back. I'd leave it and if it starts to have problems do as you were saying...cut it back. Looks good.
    Gary H.
  50. peganit2
    peganit2 Member
    Davison Mi
    I know of a cut up Virago I'd do this to.
