1986 xj900 cafe build
Discussion in 'XJ Modifications' started by Jim-boyd, Apr 29, 2014.
  1. Jim-boyd
    Jim-boyd New Member
    Lennox head nsw Australia
    Hey guys
    Got this xj from the wreckers few months back. Got her running and registered last week then started tearing it apart! Doing a cafe build.
    I got a hold of a xjr1300 tank to put on it.
    Next to come is the seat, I'm going to use black hdpe plastic for the seat pan.
    The tab on the back of the xjr tank needed to be bent up to get the right angle to use the existing tank mount.
    The existing tank mount was cut carefully out, lowered and taken back about 50mm .
  2. Jim-boyd
    Jim-boyd New Member
    Thought this view of the two tanks would be usefull to someone as I was looking for it when buying the xjr1300 tank
    Shannonside likes this.
  3. Jim-boyd
    Jim-boyd New Member
    Got the tank front mounts finished, I cut off the original mounts and reused them. I also cut a bracket (I think I took it off top of air box) in half and welded this to the frame and then the original tank mounts welded to that! Major fluke but there was no extra work needed, very easy but took a while to get position right.
  4. dean.james
    dean.james New Member
    west yorkshier
    That is good looking with that tank do like can not wait ro see end result
  5. skylrk62
    skylrk62 Active Member
    Illinois
    I love this tank! I almost went with it on mine, but decided on the '77 XS750 tank. Good luck on your project.
  6. Jim-boyd
    Jim-boyd New Member
    Getting stuff done
    So I have made a seat pan using hdpe plastic, it's easy to use but not so easy to glue. I put a pic up of the right glue to use. I also made a rear tail light and number plate bracket and also a box for the battery and all the wiring. I have cut down the triple tree and drilled some holes for led pilot lights for indicators.
    Now it's time to rip it all completely apart, get everything painted or upholstered, rebuild carbs and top end of engine :)
    Exciting!!
    Sorry for pic overload I just find it better to show what I'm doing if anyone else wants to do the same thing
    Cheers
  7. Jim-boyd
    Jim-boyd New Member
    Have had the frame and tank painted and have apoulstered the seat
    Core likes this.
  8. Jim-boyd
    Jim-boyd New Member
    Have also stripped the calipers and put new seals and some new pistons in and re sprayed the calipers aswell as the head set
  9. Orange-n-Black
    Memphis Area
    Lookin' good, like the color.
  10. MrScrambler
    MrScrambler New Member
    Sweden
    Nice tank, have the same on my xj900.
  11. bendoza
    bendoza Member
    portland, or
    very nice
  12. Core
    Core Active Member
    Switzerland
    Hey I see this thread is quite old and no end result.
    I am an Aussie, now living in Switzerland and I have just started a project very similar to yours. (base bike 1984-5 XJ900)
    I have been eyeing off the XJR1300 tank as a replacement.
    Any more detail about the tank you used, year model, etc..
    Any advice for someone following you down this road?
    A
  13. quebecois59
    Nice bike, Core !
  14. Core
    Core Active Member
    Switzerland
    Id love to see a finished xj900 project with a XJR1300 tank. Got any you can post here.
    thx
