Oversized valves to fit a Seca 550
Discussion in 'XJ Modifications' started by justind97, Dec 23, 2014.
  1. justind97
    justind97 New Member
    Ottawa
    Hey guys,
    New to the forum. I've been racing an 82 Seca 550 in some vintage races.
    The motor I have had been heavily modified, but I don't think the valves have been oversized yet. On a CB550, oversized valves can be good for up to 8hp on some motors.
    So my question is, is there oversized valves made for a 550? Looking for +1mm. If not, do the valves from another motor fit with no modifications?
    Thanks!
    Thrasher likes this.
  2. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Try the head from the FJ600.
    What has been done to your motor?
  3. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Look at the head for an FZ600 too.
  4. Thrasher
    Thrasher Member
    Or the YX600 Radian.
  5. Polock
    If you putting valves in, change the guides cut the seats and use any valve within reason
  6. justind97
    Ottawa
    Within reason, yes. I'd ideally like to go +1mm, but what I can't seem to determine is what motor will be closest to that and fit with little to no modifications.
    The head has been extensively ported and polished with a decreasing radius from outside to inside to help the Venturi effect and increase velocity.
    It was done by an ex pro bike engine builder from Toronto I believe.
  7. Polock
    little to no modifications = the valves you have now
    take a look here, it's not your engine but the ideas are the same
    http://www.aperaceparts.com/cope.html
    then get to know someone with a dyno
