mirror stand off
Discussion in 'XJ Technical Chat' started by Stormin, Dec 1, 2014.
  1. Stormin
    Stormin Member
    Poughkeepsie, NY
    So I figured I would take the mirror off while I rebuild the master cylinder. Took the mirror off the top. Then I tried to take the rod out of the master cylinder side. Dumb move. It just broke the bolt end off. I know I can drill the piece in the master cylinder side out.
    Did they use a threaded rod on the rod/stand off side? Or is it made part of it. Just wondering if I can drill and easy out that side also?
  2. pickax
    pickax Member
    Kennewick WA
    it's threaded; and just in case, recall that Yamaha mirrors are reverse (left-handed) threaded on the right (when sitting on the bike) side mirror post and also in the master cylinder mirror post mounting hole meaning that they tighten by turning counter-clockwise
  3. hogfiddles
    Correct.... Reverse-thread on the master-cylinder side. That way, if you catch a tree branch, or deer...... Or car mirror----- on either side of the bike, the mirror post can spin away by rotating toward the back of the bike rather than breaking off.
    That explains why a totaled bike can have such nice mirrors...
  4. Stormin
    Stormin Member
    Poughkeepsie, NY
    Good to know they are reverse threaded. Wish I had known this before I tried to take it off.
    Guess I will drill them out with a right hand drill. But where to find a reverse easy out and threaded rod. Or does someone sell that reverse stud?
    Thanks guys
  5. pickax
    pickax Member
    Kennewick WA
    Stormin, after you get the busted post out (I have confidence in you), you'll need some new mirrors. I have a set of used mirrors laying around that I can give you that I'm fairly certain will work. They worked on my Maxim-X & I'm pretty sure they are the same thread size and if I'm not mistaken the 1981 650's had rectangular mirrors (need some XJ-wizard confirmation here). Let me know if you're interested and I can get them to you.
    how far are you from Utica ;-)
  6. pickax
    pickax Member
    Kennewick WA
    now I see the logic behind the design!
  7. pickax
    pickax Member
    Kennewick WA
    google "Dual-Edged (Easy Out) Screw Extractors"
  8. Stormin
    Stormin Member
    Poughkeepsie, NY
    Thanks.
    I'm quite a distance from there. I'm about an hr north of nyc.
  9. Stormin
    Stormin Member
    Poughkeepsie, NY
    Me too. Now that I broke it off.
    Oh well
  10. Stormin
    Stormin Member
    Poughkeepsie, NY
    This stinks, as I need so much to get this bike back in shape, and I go and break more. But I guess I still have a few months before spring.
  11. hogfiddles
    Stormin'..... I think he asked about Utica because I'm just south of there, and have lots of parts------
  12. hogfiddles
    Pickax, yes, the 650 maxims all had the rectangular mirrors
  13. Stormin
    Stormin Member
    Poughkeepsie, NY
    Directions say 170 miles 2 hr 40 min.
    It takes me almost 2 hrs to get to albany.
  14. Stormin
    Stormin Member
    Poughkeepsie, NY
    Off topic but, how does the brake switch come out. :confused: Before I turn it the wrong way. Manual says it's just pushed in.
  15. pickax
    pickax Member
    Kennewick WA
    if you are interested in the mirrors, email your address to pick-ax @ hotmail.com (without the spaces).
    Regards,
    -steve
  16. hogfiddles
    Yes, those mirrors are what he needs. An option would be to include them in a package coming this way , then I could relay them on and that would cut down on shipping----- maybe that's what you were already thinking ..... Lol
    Dave
  17. xHondaHack
    Orange CT
    Stormin,
    The brake light switch is just "pushed in". On the bottom of the Master Cyl. there's a small hole where the switch goes in. Take a straightened out paper clip and depress the spring loaded button to release the tension and simultaneously twist and pull the switch out.
    BTW, I'm probably closer to you than hogfiddles, as I'm in the New Haven CT area. However, I don't have any stock style mirrors to offer.
    Tony
  18. Stormin
    Stormin Member
    Poughkeepsie, NY
    Thanks Tony.
    yeah, New Haven is closer.
  19. Stormin
    Stormin Member
    Poughkeepsie, NY
    Thanks Steve.
    I'll get an email out to you today.
  20. pickax
    pickax Member
    Kennewick WA
    Dave; it crossed my mind! I will cut out the middle man and send Stormin' the mirrors directly. 'Tis the Season, and I'm in the giving mood.
    Regarding the package coming your way, it looks like the riding season is done; snow on the ground - so I will get it together for you. One more trip to Lyon FR on Saturday, so it will be a week or so....
  21. hogfiddles
    No prob..... I have your brackets sitting here quietly waiting :)
  22. Stormin
    Stormin Member
    Poughkeepsie, NY
    I was thinking I should have just drilled and taped the remaining stud with a regular right hand thread put a bolt in and just tightened it to loosen the left hand thread. I think I drilled to much out to do that now
  23. Stormin
    Stormin Member
    Poughkeepsie, NY
    Well that didn't work. Taped it to 5/16" 18. Broke the bolt off it it. LoL.
    That dang thing is in there.
    I didn't try and just turn it. I kept tapping it.
    Drilling it out again.
  24. Stormin
    Stormin Member
    Poughkeepsie, NY
    Took the master cylinder apart today. I figured I would not be a happy camper doing this as the piston was pretty hard to move with the handle.
    Used a punch to tap the piston down so I could get the snap ring out. Took the snap ring out and then tapped the piston back a little then back in. Did this a couple times and it loosened up and the spring was pushing it up. Grabbed onto the piston wit small pliers and twisted it and out it came. Nice grey paste inside but wiped right out of the bore. Also ran a small wire through the tiny return hole . It was clean.
    Time to break out the brake cleaner and wash it all out. Then wait for my parts to show up.
    Anybody had any luck painting the master cylinder and brake lever?
    Now to get that mirror stud out.
  25. xHondaHack
    Orange CT
    Surprised the remaining mirror stud is still in there? Suppose the combination of dissimilar metals and moisture settling in over the years is proving to be a challenge. Once you get it ready to twist out again, you may want to try heating it up with a small propane torch and then cool it quickly with a shot of cold water. That will shock the two surfaces and hopefully relieve the bond.
    I've used semi-gloss engine enamel to freshen up the paint on mine. And, while you're at it, hit up Chacal for a new sight glass. Replace that too and the end result will be well worth all the trouble you're going through.
  26. Stormin
    Stormin Member
    Poughkeepsie, NY
    Thanks.
    I'll try the heating and cooling trick next. Wanted to get the piston out before I tried any heat.
    Have to order a sight glass and still need to order the brake lines and the front brakes will be all set. Already ordered brake pads, rebuild kits for master cylinder and caliper.
  27. Polock
    a nice set of bar end mirrors would fix this right up
  28. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Note: also purchase/install new copper crush washers at brake line connections. There's a thread about possibly heating and re-using the old ones (i can't remember where it is).
    Gary H.
  29. Stormin
    Stormin Member
    Poughkeepsie, NY
    Will do Gary.
    The lines I have been looking at come with new ones.
  30. pickax
    pickax Member
    Kennewick WA
    mirrors are on the way. post a pic when installed!
  31. Stormin
    Stormin Member
    Poughkeepsie, NY
    Thanks so much. Yes I will get pictures up when I put them on.
  32. Stormin
    Stormin Member
    Poughkeepsie, NY
    Steve. The mirrors showed up last night. Thank you . Those are some nice mirrors.
    Interesting that they changed the design along the way and put hollow studs in. Mine were solid
  33. pickax
    pickax Member
    Kennewick WA
  34. RonWagner
    RonWagner Member
    Something to remember: Left hand threads are identified by check marks on the surface the wrench mates. I know that was worded strange but its hard to put into words. Take a look at the gas fitting on a gas grill. You can also see the marks in the picture posted earlier in this post.
    rocs82650 likes this.
  35. rocs82650
    Middle Tennessee
    Makes sense to me. They look like chiseled indentations.
    Gary H.
  36. pickax
    pickax Member
    Kennewick WA
    Thanks for this. Right in front of my face all these years and I never noticed.
